    RGB Neopixel Stripe
    Lessons and Guides
    neopixel
    • T
      taunushexe
      in UIFlow 2 i get for RGB
      rgb_0 = RGBUnit((1, 2), 60)
      Why 2 Pins? normaly Neopixel uses 1 Output Pin
      if i switch to custom setup , UIFlow will also ask for Input and Output
      How can i generate
      rgb_0 = RGBUnit(2, 60) (output on port B; G2 ) no Input Pin
      I need G1 Port for a other Input
      Or can i use the normal Micropython Neopixel port?
      n = neopixel.NeoPixel(pin, 60)
        It because the RGB is a subclass of unit which is the top level class for controlling all units. Just set both numbers to the same pin
          Hello @taunushexe
          as @ajb2k3 mentioned only one GPIO (the second one) is used for the RGB unit. So the other GPIO can still be used as input. I created an example which uses GPIO1 as input to control the color of the three RGB LEDs in the RGB unit.
          See UIFlow2 Project Zone : M5Dial_RGBUnit_GPIO1_as_input_UIFlow2.0.4
