    Bug that prevents you from using string blocks as an input in the or block
    UiFlow 2.0
    1.3k
    • C
      Colobro309
      I want to use the number and string blocks as inputs for the or and and blocks.
      dissyD 1 Reply Last reply Reply Quote 0
      • dissyD
        dissy @Colobro309
        @colobro309 That isn't a bug, that's just how mathematics works.
        And/or are logical functions, they only take true/false as inputs and returns a true/false.
        Add/subtract are arithmetic functions, they only take numbers as inputs and returns a number.
        You will need to convert your string or number into a true/false value first.
        The "IF" block can do this as it returns true/false.
        Eg "If number=0 return false else return true"
        • C
          Colobro309
          In python you can use strings with the or and and keywords. The program sends a TCP request and prints the response, but if it fails it prints connection error.
          def Send_TCP_Request():
            try:
              tcpc = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
              tcpc.settimeout(1)
              tcpc.connect(('0.0.0.0', 8000))
              tcpc.send('Hello World')
              Result = tcpc.recv(1024)
              tcpc.close()
            except:
              Result = None
            return Result
          def setup():
            M5.begin()
            print(Send_TCP_Request() or "Connection Error")
