    Pb with M5Unit-Synth
    Units
    1.2k
    • Z
      Zorgroz
      No sounds with my M5 gray aand the M5 Unit Synth using the example scripts
      https://github.com/m5stack/M5Unit-Synth/tree/main/examples
      Have you tested these scripts?
      Thanks for your help.
      • K
        Kombistack
        Yes, I have tried the examples that Zorgroz refers to using my M5 Core2 and the M5 Unit Synth.
        No sounds are heard. Only the green title on the screen "Unit Synth Drum".
        Is there any documentation on how to use the M5Unit Synth with M5Flow?
        Z 1 Reply Last reply Reply Quote 0
        • Z
          Zorgroz @Kombistack
          @kombistack
          Hello @Kombistack
          With Arduino IDE, Core2 AWS and when I use Port C Blue the examples works.
          You need to change RX 16 to 13 and TX 17 to 14 in the INO sketch :
          synth.begin(&Serial2, UNIT_SYNTH_BAUD, 13, 14);
          And in the file "M5UnitSynth.h":
          void begin(HardwareSerial *serial = &Serial2, int baud = UNIT_SYNTH_BAUD,
          uint8_t RX = 13, uint8_t TX = 14);
          Happy Midi ;-)
