    WebBurner from UI FLOW2 error
    UiFlow 2.0
    5
    7
    2.7k
    • D
      dziubenko.a
      Trying to burn the firmware from using the web burner and have an error.
      Bug on the uiflow side?
        Server in accessable, It happens from time to time.
        • B
          BigAl2301
          I've been getting this error for days, including today. I assume the UIflow2 servers are down and that I should keep trying. I can't think of anything that I am doing that could cause this error. I had been workng fine previous to about a week ago.
          • Z
            zoner
            Ah
            I thought it was me. can confirm I had the same yesterday (11/3/2024)
            • B
              BigAl2301
              I resolved my problem by downloading the non-online version of UIUFlow2 Burner for the Cardputer, then burned successfully, and was then able to continue using the browser-based UIFlow V2 to work on my project.
                If you are getting this for a while, you need to clear out your temperory files and data and reset the browsers. it could be one of the temp files blocking the site
                  Hello @racky
                  FYI: I've checked the URL you posted on VirusTotal and it did not indicate a problem. See result here.
