New M5Stack Core 2 device captive buttons
 Hi, As per the title does anyone else have the latest device have you had any success in using your device? I tried to flash with UIFlow 2 seems reboot fine with the UIFlow UI but when you try to use the desktop (Windows 10) version of UIFlow app it can't connect. M5 Burner works fine picks up the device. Arudino IDE also worked initially but that caused issues had to erase the device (eventually) and the flash the UIFlow base rom then flash to version 2.x. Do the captive buttons work at all there is no idea if they do I was told to hold down the middle button to display a dev menu but that doesn't work. Thank in advance and apologies for the dumb questions new to all this. Trev
