    SyntaxError: invalid syntax
    UiFlow 2.0
    1.9k
      mchott
      Hi .. if I run my current code on my M5Dial there is an issue. I got an "invalid syntax" but in line 41 is nearly nothing incorrect.
      41: mqttMsg = None
      File "<stdin>", line 41
      If I change the order of the lines, I get the same issue but for a different line and the old one is still there before the new one.
      41: TempKlima = None
      I think there is nothing wrong with these lines and I´m looking at the wrong place of my code.
        ajb2k3 @mchott
        @mchott the line error doesn’t always report the correct line unless you know how to read it. I recently found a syntax error due to quote mark formatting
