UIFlow 2.0.1 HTTP GET and parse JSON
Hi team,
I'm trying to complete the simplest of all possible projects, and for the life of me after two days of troubleshooting I simply can't figure it out.
Device: Core2
OS: Mac OS 14.2.1
Software: UIFlow v2.0.1I'm trying to HTTP GET a local JSON endpoint with some data.
I started off trying to program this with the visual interface, but found that I quickly had to switch to python because of the missing 'urequests' lib (there's another thread about that on this forum).
Using the 'requests' library, I found that I can perform the GET request and actually get a 200 status OK back. However, when using the response.json() call, the program hangs with no error and no output.
If I run the same requests in python3 on my desktop environment, it all works.
Here's where I got to:
import os, sys, io import M5 from M5 import * import network import requests title0 = None statTitle = None resTitle = None stat = None res = None # http_req = None wlan = None status = None def setup(): global title0, statTitle, resTitle, stat, res, http_req, wlan, status M5.begin() Widgets.fillScreen(0x222222) title0 = Widgets.Title("Powermonitor", 3, 0xffffff, 0x0000FF, Widgets.FONTS.DejaVu18) statTitle = Widgets.Label("Status:", 2, 28, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18) resTitle = Widgets.Label("Response:", 2, 57, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18) stat = Widgets.Label("...", 110, 29, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18) res = Widgets.Label("...", 111, 57, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18) stat.setText(str('Fetching')) http_req = requests.get('http://192.168.10.22/api/v1/data') status = http_req.status_code stat.setText(str(status)) print(str(http_req.status_code)) print(str(http_req.reason)) print(str(http_req.encoding)) # print(str(http_req.raw)) # print(str(http_req.text())) data = http_req.json() print(str(data)) # print(str(http_req.json())) # http_req.close() # print(dir(responseJson)) # print(responseJson()) # res.setText(str(http_req.json())) def loop(): global title0, statTitle, resTitle, stat, res, http_req, wlan, status M5.update() if __name__ == '__main__': try: setup() while True: loop() except (Exception, KeyboardInterrupt) as e: try: from utility import print_error_msg print_error_msg(e) except ImportError: print("please update to latest firmware")```
Are you sure its hanging and not taking ages to get a response?
Yes, the endpoint responds almost instantly. Also the status code immediately comes back as as '200'.
