    PaHub Code issue in UIFlow2
    UiFlow 2.0
    2.2k
      @m5stack I'm trying to write an example of using the PaHub in UIFlow2 but found a bug:
        env3_0 = ENVUnit(i2c=i2c0, type=3)
        env4_0 = ENVUnit(i2c=PAHUBUnit(i2c=i2c0, channel=0), type=4)
        pahub_0 = PAHUBUnit(i2c=i2c0, channel=0)
      Should be:
        env3_0 = ENVUnit(i2c=PAHUBUnit(i2c=i2c0, channel=1), type=3)
      but no matter what I try, the Pahub always crashes with "device not found"
        Hello @ajb2k3
        remember, PaHub and ENVIII share the same I2C address (0x70) by default, e.g. if not modified. As discussed here.
          ajb2k3 @felmue
          @felmue said in PaHub Code issue in UIFlow2:
          Hello @ajb2k3
          Thanks but I have an issue with solving your code. in the line:
          env3_0 = ENVUnit(i2c=PAHUBUnit(i2c=i2c0, channel=0, address=0x71), type=3)
          You have attached the Address to the ENV but we need to override the pahub_0 definition to include the address or it still looks to address 0x70 and this I can't work out.
            Hello @ajb2k3
            the additional address parameter is for the PaHub. E.g. I modified the PaHub to use I2C address 0x71 (instead of default address 0x70).
            BTW: ENVIII alternate I2C address is 0x56.
              ajb2k3 @felmue
              Hello @ajb2k3
              I've changed the Hub address to 71 but the definition is for pahub_0 but you code has env defined as PAHUBUnit
              hence the confusion
                Hello @ajb2k3
                please find an example in the UIFlow2 Project Zone called M5Dial_PbHub_EnvIII_EnvIV.
                It features an M5Dial, PaHub (modified I2C address 0x71), Env III (channel 0) and Env IV (channel 1).
                M5Dial
                PaHub (0x71) -|
                              |- ch0 - ENV III (0x44, 0x70)
                              |- ch1 - ENV IV (0x44, 0x76)
                Is that what you are looking for?
                BTW: my code has env defined as PAHUBUnit because the Env III and Env IV are connected to channel 0 and channel 1 of the PaHub.
                  Thanks but just a note for your example, Use the execute code but ad a hash (#) before the note
                    Thanks here we are
                      Hello @ajb2k3
                      nice! And thanks for the tip with the # before the note.
