    Lesson 8. Servo. Analog clock
    Lessons and Guides
    16.3k
    • DimiD
      Dimi
      Hello! Today we will learn how to control a servo using M5Stack
      Servo (from lat. servus — servant, assistant, servant), or servomechanism — mechanical transmission with automatic correction state through internal negative feedback, in accordance with the parameters set from outside. The servo has three wires: + power, - power and data wire. In order to rotate the servo to the desired angle, it is necessary to send the data wire, the pulse duration required, as shown in figure 1.
      Figure 1. Timelines impulse control
      The prerequisites for lesson:
        1. M5Stack;
        1. cable USB-C standard;
        1. colored wires from the standard set;
        1. the servo with the arrow. Model SG90;
        1. photo paper 10 x 15 cm;
        1. nail Polish;
        1. hot melt glue;
        1. Board for mounting.
      Purpose:
      Make an analog clock with the hour hand. The time setting will be done with the integrated buttons and screen M5Stack. Every hour the device will make a sound.
      Step 1. Unpack Your servo (Fig. 1.1);
      Figure 1.1. New kit with servo
      Step 2. Take only the selected components and leave the others (Fig. 2);
      Figure 2. Selection of the necessary components servo
      Step 3. Take the nail (Fig. 3) and paint the arrow (Fig. 4);
      Figure 3. Nail polish and arrow servo
      Figure 4. Painting arrows
      Step 4. Print the photo of a dial for the watch on a normal printer (paper size 10 x 15 cm; the print file attached Download section), then make a hole with a screwdriver (Fig. 5);
      Figure 5. Preparation of the dial
      Step 5. Using a glue carefully attach the dial to the body of the servo (Fig. 6);
      Figure 6. Fit the dial to the body of the servo
      Step 6. Do the same design on a wooden platform and set the arrow (Fig. 7);
      Figure 7. Installation and Assembly hours
      Step 7. Use colored wires for connection (Fig. 8);
      Figure 8. Connect the servo to the device
      Step 8. Connect the wires to the necessary pins as shown in figure 9;
      Figure 9. Wire data to the G5, wire + supply to 5V, leads - power supply to GND
      Step 9. Connect the device to the computer using the USB cable C (Fig. 10);
      Figure 10. Connecting to a PC
      Step 10. Create a new project in the Arduino IDE and write the code:
      #include <M5Stack.h>
      int servoPin = 5;
      // default time
      int H = 0;
      int M = 59;
      int clockTable[12][2] = { // calibrate clock table
      {28, 157}, {157, 130}, {130, 103}, {103, 79},
      {76, 52}, {49, 28}, {28, 9}, {9, 130},
       {130, 103}, {103, 79}, {79, 52}, {52, 28}
      int S = 0;
      unsigned long cMls;
      unsigned long pMls = 0;
      bool dots = false;
      int servoPulse(int angleDegrees)
      int pulseWidth = map(angleDegrees, 0, 180, 544, 2400);
      return pulseWidth;
      void servoSet(int oldAngle, newAngle, int) {
      int pulseWidth;
      if (oldAngle == newAngle)
      return;
      else if (oldAngle < newAngle)
      for (int i = oldAngle; i <= newAngle; i++){
      pulseWidth = servoPulse(i);
      digitalWrite(servoPin, HIGH);
       delayMicroseconds(pulseWidth);
      digitalWrite(servoPin, LOW);
      delayMicroseconds(20000 - pulseWidth);
      else if (oldAngle > newAngle)
      for (int i = oldAngle; i >= newAngle; i--){
      void setH(bool readOnly = false) {
      if (!readOnly) H++;
      if (H > 11) H = 0;
      M5.Lcd.fillRect(80, 110, 70, 42, 0x00);
      M5.Lcd.setTextColor(0xfbe4);
      M5.Lcd.setTextSize(6);
      M5.Lcd.setCursor(80, 110);
      servoSet(clockTable[H][0], clockTable[H][1]);
      if ((H < 10) && (H != 0)) M5.Lcd.print(0);
      M5.Lcd.print(((H == 0) ? 12 : H));
      void setM(bool manual = false, bool readOnly = false) {
      if (!readOnly) M++;
      if (M > 59)
      M = 0;
      if (!manual)
      setH();
      M5.Speaker.tone(660);
      delay(50);
      M5.Speaker.mute();
      M5.Speaker.tone(440);
      delay(50);
      M5.Speaker.mute();
      M5.Speaker.tone(820);
      delay(50);
      M5.Speaker.mute();
      M5.Lcd.fillRect(180, 110, 70, 42, 0x00);
      M5.Lcd.setCursor(180, 110);
      if (M < 10) M5.Lcd.print(0);
      M5.Lcd.print(M);
      void setS() {
      S++;
      if (S > 59)
      S = 0;
      setM();
      if (dots)
      M5.Lcd.fillRect(150, 110, 29, 42, 0x00);
      else
      M5.Lcd.setCursor(150, 110);
      M5.Lcd.print(":");
      dots = !dots;
      m5.begin();
      pinMode(servoPin, OUTPUT);
      M5.Lcd.setBrightness(200);
      M5.Lcd.setTextColor(0xffff);
      M5.Lcd.setTextSize(3);
      M5.Lcd.setCursor(65, 20);
      M5.Lcd.print("Servo Clock");
      M5.Lcd.setTextColor(0x7bef);
      M5.Lcd.setTextSize(2);
      M5.Lcd.setCursor(55, 60);
      M5.Lcd.print("please, setup time");
      M5.Lcd.setCursor(60, 215);
      M5.Lcd.printf("H");
      M5.Lcd.setCursor(250, 215);
      M5.Lcd.printf("M");
      setH(true);
      setM(true, true);
      cMls = millis();
       if (M5.BtnA.wasPressed()) setH();
      if (M5.BtnC.wasPressed()) setM(true);
      if ((cMls - pMls) > 1000)
      pMls = cMls;
      setS();
      m5.update();
      Step 11. Upload the sketch to the device (Fig. 10.1);
      Figure 10.1. Uploading your sketch to the device
      Step 12. After loading the sketch, the unit will restart and will appear on the screen menu;
      Figure 11. The display menu
      Step 13. Set the time using buttons H and M and wait for the arrival of the next hour (Fig. 12);
      Figure 12. Watch works
      Download
      Video demonstration of the work you can download here https://yadi.sk/i/sOEpVp7r3RkPoY
      The sketch can be downloaded here https://yadi.sk/d/1kpt9gH33Rm49M
      A file for printing of the dial can be downloaded here https://yadi.sk/d/Dr7CWpnW3Rm53V
      • O
        olivier
        hi,
        thank you for your lesson (all lesson).
        Very great for me, i m beginer.
        Have you lesson with bluetooth
        thank you
        DimiD 1 Reply Last reply Reply Quote 1
        • DimiD
          Dimi @olivier
          @olivier thanks! in future
