    M5Dial & CAN using PlatformIO
    General
    5.9k
      samarkh
      Has anyone got the m5Stack dial to work with the CAN (Controller Area Network) Unit SKU: U085 using PlatformIO?
      I have got all the examples to compile OK but now I want to connect to the CAN unit I get errors.
      Yours Simon M.
        Hello @samarkh
        which examples have you tried? Maybe this example code can help?
          samarkh
          The solutions I found worked are
          For the M5Dial
          Platform.ini :-
          ; PlatformIO Project Configuration File
          ; Build options: build flags, source filter
          ; Upload options: custom upload port, speed and extra flags
          ; Library options: dependencies, extra library storages
          ; Advanced options: extra scripting
          ; Please visit documentation for the other options and examples
          ; https://docs.platformio.org/page/projectconf.html
          [env:m5stack-stamps3]
          platform = espressif32
          board = m5stack-stamps3
          framework = arduino
          lib_deps =
          m5stack/M5Dial@^1.0.2
          m5stack/M5Unified@^0.1.11
          m5stack/M5GFX@^0.1.11
          platform_packages = framework-arduinoespressif32@https://github.com/espressif/arduino-esp32/archive/refs/tags/2.0.14.zip
          upload_speed = 1500000
          monitor_speed = 115200
          Start of code:
          • @file encoder.ino
          • @author SeanKwok (shaoxiang@m5stack.com)
          • @brief M5Dial Encoder Test
          • @version 0.2
          • @date 2023-10-18
          • @Hardwares: M5Dial
          • @Platform Version: Arduino M5Stack Board Manager v2.0.7
          • @Dependent Library:
          • M5GFX: https://github.com/m5stack/M5GFX
          • M5Unified: https://github.com/m5stack/M5Unified
          #include "M5Dial.h"
          void setup()
          auto cfg = M5.config();
          M5Dial.begin(cfg, true, false);
          etc
          and for the M5 Core2
          Platformio.ini =
          [env:m5stack-core2]
          board = m5stack-core2
          framework = arduino
          platform_packages =
          lib_deps =
          and start of code:
          • Minimum code to get a display on the
          • M5Stack Core2
          • Using PlatformIO and Arduino
          #include <Arduino.h>
          #include <M5Unified.h>
          #include <M5GFX.h>
          void setup()
          etc
          and for the M5Stack Core3S
          Platformio.ini
          [env:m5stack-cores3]
          board = m5stack-cores3
          framework = arduino
          lib_deps =
          tinyu-zhao/BMI270_Sensor@^0.0.1
          m5stack/M5CoreS3@^0.0.4
          platform_packages =
          build_flags =
          -DESP32S3
          -DBOARD_HAS_PSRAM
          and code start
          • Copyright (c) 2023 by M5Stack
          •              Equipped with M5CoreS3 sample source code
          • Visit for more information:
          • https://docs.m5stack.com/en/core/CoreS3 - Docs
          • https://github.com/m5stack/M5CoreS3 - GitHub
          • Describe: Hello World
          • Date: 2023/5/3
          #include <M5CoreS3.h>
          void setup()
          M5.begin(true, true, false); // Init M5CoreS3.
          etc
          Yours Simon M
            samarkh
            As yet I have only got the M5Stack ATOMIC CANBus Base and CANBus Unit to work with the following code using Atom Lite & Atom Matrix :-
            #include "M5Atom.h"
            #include <ESP32CAN.h>
            #include <CAN_config.h>
            #define CAN_BASE // Remove to use external CAN bus via Grove cable
            //#define CAN_RECIEVER // Remove to make sender
            #define CAN_MSG_ID 0x001
            CAN_device_t CAN_cfg; // CAN Config.
            unsigned long previousMillis = 0; // will store last time a CAN Message was sent // send. 将存储上次发送CAN消息的时间。
            const int interval = 80; // interval at which send CAN Messages (milliseconds).
            const int rx_queue_size = 10; // Receive Queue size.
            int LedNumberCount = 0;
            int waitCANData = 0;
            uint8_t msgcnt = 0;
            void setup()
            M5.begin(true, true, true);
            Serial.println("Atom Install OK....");
            M5.dis.fillpix(CRGB(100, 0, 0)); //Fill the LED Matrix RED
            delay(2000);
            #ifdef CAN_BASE // CAN base is used
            //default
            CAN_cfg.tx_pin_id = GPIO_NUM_22;
            CAN_cfg.rx_pin_id = GPIO_NUM_19;
            #else
            // Grove
            CAN_cfg.tx_pin_id = GPIO_NUM_26;
            CAN_cfg.rx_pin_id = GPIO_NUM_32;
            #endif
            CAN_cfg.speed = CAN_SPEED_500KBPS;
            CAN_cfg.rx_queue  = xQueueCreate(rx_queue_size, sizeof(CAN_frame_t));
            ESP32Can.CANInit();
            Serial.println("CAN Install");
            M5.dis.fillpix(CRGB(0, 100, 0));  //Fill the LED Matrix GREEN
            M5.dis.fillpix(CRGB(HUE_GREEN)); //Fill the LED Matrix GREEN
            #ifdef CAN_RECIEVER
            Serial.println("Set as RECIEVER");
            #else
            Serial.println("Set as SENDER");
            #endif
            void loop()
            unsigned long currentMillis = millis();
            #ifdef CAN_RECIEVER
            // recieve CAN Message
            CAN_frame_t rx_frame;
            if (xQueueReceive(CAN_cfg.rx_queue, &rx_frame, 3 * portTICK_PERIOD_MS) ==  pdTRUE)
                if (rx_frame.FIR.B.FF == CAN_frame_std)
                    Serial.printf("New standard frame");
                else
                    Serial.printf("New extended frame");
                if (rx_frame.FIR.B.RTR == CAN_RTR)
                    Serial.printf(" RTR from 0x%08X, DLC %d\r\n", rx_frame.MsgID, rx_frame.FIR.B.DLC);
                else
                    Serial.printf(" from 0x%08X, DLC %d, Data ", rx_frame.MsgID, rx_frame.FIR.B.DLC);
                    for (int i = 0; i < rx_frame.FIR.B.DLC; i++)
                        Serial.printf("0x%02X ", rx_frame.data.u8[i]);
                    Serial.printf("\n");
                    if (rx_frame.data.u8[0] == 0x01)
                        CAN_frame_t tx_frame;
                        tx_frame.FIR.B.FF   = CAN_frame_std;
                        tx_frame.MsgID      = CAN_MSG_ID;
                        tx_frame.FIR.B.DLC  = 8;
                        tx_frame.data.u8[0] = 0x02;
                        tx_frame.data.u8[1] = rx_frame.data.u8[1];
                        tx_frame.data.u8[2] = 0x00;
                        tx_frame.data.u8[3] = 0x00;
                        tx_frame.data.u8[4] = 0x00;
                        tx_frame.data.u8[5] = 0x00;
                        tx_frame.data.u8[6] = 0x00;
                        tx_frame.data.u8[7] = 0x00;
                        ESP32Can.CANWriteFrame(&tx_frame);
            #else
            // Send CAN Message
            if (currentMillis - previousMillis >= interval)
            // ESP32Can.CANInit();
            previousMillis = currentMillis;
            tx_frame.data.u8[0] = 0x01;
            tx_frame.data.u8[1] = msgcnt;
                // ESP32Can.CANStop();
                msgcnt++;
                if (msgcnt > 29)
                    msgcnt = 0;
                else
                else
                    if (rx_frame.data.u8[0] == 0x02)
                            if (rx_frame.data.u8[1] < 25)
                            M5.dis.drawpix(rx_frame.data.u8[1], CRGB(100, 0, 0));
                        else if (rx_frame.data.u8[1] > 27)
                            M5.dis.fillpix(CRGB(0, 0, 20));
                        waitCANData = 0;
            #endif
            // waitCANData
            M5.update();
            if (M5.Btn.isPressed())
            M5.dis.clear();
            esp_restart();
            delay(10);
            when I modify it to work with the Core2, it compiles OK but no echo back. what am I missing?
              Hello @samarkh
              I assume you've adapted the TX and RX GPIOs for M5Core2 accordingly, yes?
                samarkh @felmue
                I used
                /* set CAN pins */
                // GROVE connector GPIO pins
                CAN_cfg.tx_pin_id = GPIO_NUM_32; // Use this order only
                CAN_cfg.rx_pin_id = GPIO_NUM_33;
                and I'm able to see activity on the CAN bus using an oscilloscope.
                  Hello @samarkh
                  these GPIOs look ok to me. Hmm, not sure why it doesn't work on M5Core2 though. Sorry.
                  • U
                    uberdweeb
                    I did get this to work. I'm using this library for the CAN part:
                    https://github.com/aaknitt/esp32_can/tree/master
                    Put this code in lib and change the pin designations in esp32_can.cpp:
                    ESP32CAN attribute((weak)) CAN0(GPIO_NUM_1, GPIO_NUM_2) ;
                    platformio.ini looks like this:
                    framework = arduino
                    lib_deps =
                    https://github.com/collin80/can_common
                    https://github.com/plapointe6/EspMQTTClient
                    m5stack/M5Dial
                    m5stack/M5Unified
                    Plug it into Port B
                    Setup code is like:
                    CAN0.setCANPins(GPIO_NUM_1, GPIO_NUM_2);
                    USBSerial.println("Set CAN pins...");
                    CAN0.begin(500000);
                    USBSerial.println("CAN has started...");
                    CAN0.watchFor();
                    CAN0.setCallback(0, theCanDecoder);
                    If you want full code I can probably clean this all up and publish on Git.
