    Blue Lorawan Module
    PRODUCTS
    8.8k
    • qlionQ
      qlion
      Hi
      Is there a example to connect a M5stack to the TTN network?
      https://m5stack.github.io/m5-docs/#/en/product_documents/modules/module_lorawan
      Thanks.
      • m5-docsM
        m5-docs @qlion
        @qlion
        Sorry, we do not have example about TTN
        M5Stack documentation URL
        https://docs.m5stack.com
        • qlionQ
          qlion
          Hi
          I managed to get connected with the following.
          #include <M5Stack.h>
          HardwareSerial Serial2(2);
          int period = 158000;
          unsigned long time_now = 0;
          String cmd_DEF = "AT+FDEFAULT";
          String cmd_OTTA_mode = "AT+MODE=LWOTAA";
          String cmd_DevEui = "AT+ID=DevEui";
          String cmd_JOIN = "AT+JOIN=FORCE";
          String cmd_send_data = "AT+MSG="Data to send"";
          Wire.begin();
          // Lcd display
          M5.Lcd.setBrightness(100);
          M5.Lcd.fillScreen(BLACK);
          M5.Lcd.setCursor(10, 10);
          M5.Lcd.setTextColor(WHITE);
          M5.Lcd.setTextSize(1);
          M5.Lcd.printf("LoraWAN Network");
          delay(300);
          delay(150);
          M5.Lcd.setCursor(0, 10);
          for(int i=0; i<200; i++) {
          M5.Lcd.setBrightness(i);
          delay(2);
          Serial.begin(115200);
          Serial2.begin(9600, SERIAL_8N1, 16, 17);
          Serial2.flush();
          /* LoRaWAN Init */
          M5.Lcd.println("Setting up the LoraWAN Connetion");
          Serial2.println(cmd_DEF);
          delay(2000);
          Serial2.println(cmd_OTTA_mode);
          delay(1000);
          Serial2.println(cmd_DevEui);
          delay(1000);
          delay(3000);
          M5.Lcd.println("Joining Network.");
          Serial2.println(cmd_JOIN);
          delay(3000);
          M5.Lcd.println("Message will be send in 155000ms, when next Band is availible");
          if(millis() > time_now + period){
          time_now = millis();
          M5.Lcd.println("Sending Data.");
          Serial2.println(cmd_send_data);
          if(Serial2.available()) {
          int ch = Serial2.read();
          Serial.write(ch);
