    M5Dial - Button not working?
    UiFlow 2.0
    1.7k
    • F
      Fredde
      Hey guys,
      New here and new to UIFlow2. Got a M5Dial that I am playing with. I got the encoder working etc. But I can't get the inbuilt button press in it working.
      I have the "Button" added to my hardware list (it was included automatically based on my M5Dial hardware profile). Under it I can find the event "When button BtnA was X" which I have added. I have put a simple "set label0 to Hello". But it never triggers. I've tried pressed, clicked, held etc.
      I tried in my loop as well to do a "if pressed" but that doesnt work either.
      What am I missing? Do I need to initialise or configure the button somehow?
      Here is the code generated for it,
      def btnA_wasClicked_event(state):
      global Background, image1, image2, image3, image4, label0, rgb, rotary, http_req
      label0.setText(str('Clicked!'))
      def setup():
      BtnA.setCallback(type=BtnA.CB_TYPE.WAS_CLICKED, cb=btnA_wasClicked_event)
        Hello @Fredde
        make sure you have the Update button, touch, etc. in loop block activated in loop. E.g.
        def loop():
          global label0
          M5.update()
        • F
          Fredde @felmue
          @felmue Amazing felmue! Thanks that was it!
