    USB mode on the M5Stack Core S3
    UiFlow 2.0
    2.6k
    • W
      windegg
      How do you set the USB mode on the M5Stack Core S3 for a connection with UIFlow2?
        ajb2k3 @windegg
        @windegg once you have burned the UIFlow2 firmware, you go into uiflows device selector to connect in USB mode however, usb mode only works with certain web browsers
        • W
          windegg
          @ajb2k3 Thanks for your reply :-)
          The connection via web browser for the USB mode worked. However, I am also looking for a way to establish an offline USB connection with the M5Stack Core S3 via the UIFlow Desktop IDE (V 1.0.17). This was possible with the M5Stack Core 2.
            ajb2k3 @windegg
            @windegg The desktop IDE hasn't been updated in a long time and (from what I was told) will not be updated until UIFlow2 reaches a stable (none Alpha test) version.
            W 1 Reply Last reply Reply Quote 2
            • W
              windegg @ajb2k3
              @ajb2k3 Thank you very much for the clarification! :-)
