    M5Stack Core 2 External WiFi antenna
    Core 2
    4.2k
      momopl
      Hello everyone,
      Has anyone here tried installing an external WiFi antenna on the M5Stack Core 2? The built-in 3D antenna provides fairly limited performance, and I'm thinking about trying to mount an antenna with an SMA connector. My questions are:
      Where on the PCB should I solder the wires for the SMA connector after removing the 3D antenna?
      Where can I find the PCB schematic for the Core 2?
      Any advice or experiences shared would be greatly appreciated!
      • G
        gavin67890 @momopl
        @momopl,
        Most things M5Stack are split between store. and docs., so see here for the schematic.
        I was curious, so I had a look inside my Core2 and it looks like there might even be a convenient breakout port for the SMA connector behind the label.
        • U
          UnumDesignum
          If you carefully look under the 3D antenna, you can see there are pre-soldered areas that look like for receiving an U.FL connector. Quite challenging to access to though. Maybe desolder the 3D antenna first.
