Displaying an image on a Core2
Hi All,
I have tried multiple ways to display an image on my Core2, it either does not compile or the image is display as a distorted mess.
I am able to display the image on an ESP32 development board connected to 1.3" OLED using the Adafruit Graphic library, so I am not sure if I need to "recreate" the "hex map", I have tried Ricky-Dink online convertor and again, my code refuses to compile.
I have searched the forum and so far have not found any guidance, I am using the M5 Unified.h and not Core2.h
Any guidance would be most appreciated.
Kind Regards
Paul -
The information is about somewhere but on the ESP32 ports for M5Stack, Images must be smaller then a certain file size and the save format must be of a certain format. I you search Github for my UIFlow Handbook, you will find this data in the PDF.
