    AirTube to AtomS3
    Units
    1.1k
    • G
      Gory9387
      Im trying to connect this unit:
      https://docs.m5stack.com/en/unit/tube_pressure
      to AtomS3, but dont know which pin to set as the sensor pin(I have tried pin 1 and 2)
      I have also m5stickC, and there everything fine. this is the code example that works for me there:
      #include <Arduino.h>
      int sensorPin = 33; // Sensor Pin
      Serial.begin(115200);
      pinMode(sensorPin, INPUT); //Sets the specified pin to input mode. 设置指定引脚为输入模式
      float raw = analogRead(sensorPin); // read the value from the sensor. 读取当前传感器的值
      float Vout = raw/40953.6;
      float P = (Vout-0.1)/3.0
      300.0-100.0;
      Serial.printf("pressure: %f.2 Kpa\r\n", P);
      delay(500);
      so if someone can tell me how to connect this pressure sensor to AtomS3, I'll be grateful.
      Thanks!
