    How can we use USB CDC on AtomS3 for serial debugging?
    UiFlow 2.0
    1.6k
    • K
      kotobuki
      I want to use the USB CDC port on AtomS3 (Lite) for serial debugging. It seems that there are no dedicated blocks for USB CDC in Alpha-26. Is it possible to use USB CDC with the UART blocks (e.g., Init UART 0 with or UART 0 setup) with a particular configuration?
      Thank you very much in advance,
      Shigeru
      • K
        kotobuki
        I found that the print block in the Text category works fine without configuring pins.
        I overthought about this issue.
        Thanks,
        Shigeru
