    Battery follow up in UI Flow2
    8 Posts 4 Posters 7.7k Views 2 Watching
      csierra67
      Hi there
      I am starting to experiment with Core S3 . I could not find the Power block available in UI Flow 1 that allows to follow battery remaining capacity, battery voltage and possibly battery current.
      The block should be under hardware but there is nothing like that to add.
      I am missing something or is this block just not yet implemented ?
      Thanks a lot for your comments
      csierra67
        The S3 series is not compatible with UIFlow 1 due to the way it works.
          csierra67
          Thanks a lot, but as the title indicates is there a battery follow up of Core S3 in UI Flow ?
            csierra67 @csierra67
            I mean UIFlow 2
              csierra67
              After 157 views and No answer, I conclude that nobnody has an answer ;-)... Poor reactivity of this forum ;-(
              Core 2 being able to be programmed with UI Flow 1 and UI Flow 2 and as the battery follow up exists in UI Flow2, I conclude that it is missing for now in UI Flow2 and hopefully M5 stack will provide it.
              • lbuqueL Offline
                lbuque
                @csierra67 Python's API, blockl does not yet exist.
                import M5
                # Battery percentage
                M5.Power.getBatteryLevel()
                # set Charge Current
                M5.Power.setChargeCurrent()
                  csierra67 @lbuque
                  @lbuque
                  Thanks for the explanation. It is a pity, when the MCU runs on battery, there is no monitoring that would allow the user to take action when the battery comes close to the threshold value.
                  • stjofrS Offline
                    stjofr
                    This code will help :
                     print(M5.Power.getBatteryLevel())
                    Stef Code
                    Project Management Director and Editor
                    in Database Software Systems Development
                    https://stjo.fr
