    DIY Mini Proto Board
    15 Posts 3 Posters 52.8k Views 1 Watching
      Kryten
      @SR Here are a protoboard case STL file. If you are capable you can redesign and make for your own.
      https://www.thingiverse.com/thing:2754642
        SR
        @Kryten Thank you, this looks already good.
        Better would be the housing of the base board because I need to align the pin break out area with the stands of the proto board. But it's a beginning.
          Kryten
          @SR aWho big is your Proto board? any drawing?
            SR
            It's a standard 7x5 cm board with interconnected holes. The mini bread board on it measures ~ 4.5 x3.5 cm.
              Kryten
              Cool. I will see if can find the time to make a "shield" like that. So you just move the bottom PCB and battery (if needed) over to the printed version.
                SR
                My idea for a housing of the proto board would be more like a case that can pick up the complete M5Stack inclusive the button board without disassembling it at all.
                  Kryten
                  Like this?
                    SR
                    No. There is the button module completely replaced. I would like to keep it attached. I thinking about some kind of encloser around the housing of the M5Stack with a slide in mechanism. That was also the reason way I was asking in this thread for STL model of the hole case.
                      Kryten
                      So you want to hae the M5 as is and slide in to a module with your protoborad on?
                      Something like this?
                        SR
                        Yes, pretty close to your design.
