    195 Posts 79 Posters 551.8k Views 13 Watching
      arkieguy
      Let me start by saying that I love the way UIFlow2 is going. It seems a lot more logical (with the ability to include selected software / hardware / etc features). With that said, I do have a few questions related specifically to the Atom S3 (with the display):
      • Any idea when (if?) the new Atomic QR-Reader will be added to UIFlow 2 (or docs for using it with the UART options)? I haven't had any luck with it so far (couple of hours playing around with it).
      • Is the LED light (behind the "reset" button) accessible? If I try to use the LED (BuiltIn) it throws an error.
      • I have a use case for the Atom S3 as a clock in an environment with no WiFi. The "RTC" functionality seems to "work" but isn't battery backed up. I've added a "Songhe DS3231SN Real Time Clock Module AT24C32" from Amazon that communicates via I2C (and has a rechargeable battery) but the RTC hardware doesn't have a way to point to the external RTC (seems to be pointing to the internal or maybe just pulling from WiFi when I have WiFi). Suggestions?
        flex
        @iamliubo said in UiFlow 2.0 Alpha verison discuss(how-to, bug, feature request or sometings):
        @iamliubo
        Hi Liubo,
        • there is problem using the webpage UIFLow 2.0 on IOS: it is not possible to create or modify an UI item (it is working on UIFlow 1)...
        • more generally, what is the most efficient way to fill a bug report for UIFlow 2.0
        Thanks, Pascal
          ciconde
          I have a Servo2 with Core2 but I don't see it in "Modules".
          Can you please add it so we can use it?
            ciconde
            Several screen pages desired.
            Suggest to have several pages with different elements on them (like the scenes in Scratch) so it's easy to create a multi page application.
            Then an UI instruction for switchToPage(n) would disable and hide all elements but the ones pertaining to that page, potentially applying also separate background color.
              ciconde
              EzData2 Debugger wanted
              It would be great to have an EzData2 HMI such as we had in EzData1 "debugger".
              Thanks for such a great job!
                ciconde
                  ciconde
                  RGB software element is not working - color can't be changed
                    ciconde
                    Core2 firmware - start screen doesn't refresh User account until navigated out and back in
                      ciconde
                      Device manager - apps - ability to open app in editor needed.
                      I tend to store there the apps, so I'd like to load them from device same as in UiFlow1
                        ciconde
                        Slider unit missing
                          jazztunes
                          Perhaps previously reported, but I don't see the "red port" rotary encoder unit (U135) in UIFLOW2. Any ideas?
                          Alpha-24
                          V2.0.0
                          F 1 Reply Last reply Reply Quote 2
                            flex @jazztunes
                            @IAMLIUB0
                            do developers of UIFlow are reading M5Stack Community Forum, to take into account the bugs we can encounter, or is there any special bug report to do somewhere else?
                            I notified few months ago and also recently, that UIFlow 2.0 doesn't work with Apple IOS, while UIFlow 1.12 works correctly, in term of creating designing UI items...
                            Thank you for your feedback
                            Pascal
                            • E Offline
                              erich
                              Hi there,
                              Sorry I just need a confirmation: Alpha-26: Is it right built-in Infrared is not (yet, hopefully) supported on the M5StickC PLUS? I cannot find IR in the integrated hardware menu.
                              Also, I have noticed support for M5StickC Plus 2 , is it an upgraded M5StickC Plus not out yet? I am very interested ;)
                              Thanks for your answers!
                              G B 2 Replies Last reply Reply Quote 0
                              • G Offline
                                gavin67890 @erich
                                Hi @erich,
                                There's a snippet here about StickPlus2
                                https://twitter.com/M5Stack/status/1682320261708926977
                                Also interested, but it seems a limited spec change to overcome obsolescence. If there is work being done on the IR code blocks, it would be a nice feature to get full NEC IR code support.
                                • E Offline
                                  erich @gavin67890
                                  @gavin67890 thanks a lot for the link!
                                  I agree it does not look much different from the current stickcplus. Also I see it was supposed to be launched end of July… let’s wait and see
                                    kotobuki
                                      jonbloom
                                      Just picked up some M5 Dials, they're great. Could we possible get BLE GATT support in UIFlow 2? The UART blocks are great, but allowing services/characteristics/notifications with BLE would open up for interacting with various BLE based IoT devices easily.
                                      • B Offline
                                        bazman @erich
                                        @erich
                                        Here's the FCC submission for M5StickC Plus 2 include internal and external photos:
                                        https://apps.fcc.gov/eas/GetApplicationAttachment.html?id=6654502
                                        Apparent differences to M5StickC Plus 1.1:
                                        • AXP192 is removed as it is end-of-line
                                        • Magnet is now one small disc instead of two small bars
                                        • battery lead is socketed
                                        • now one board instead of two
                                        • IC is ESP32-PICO-V3-02 instead of ESP32-PICO-D4 (now doesn't support external PSRAM, not relevant though). PICO-V3 has extra pin 20 for internal use.
                                        • 200mAh battery instead of 120mAh
                                        • Not clear where the buzzer is or whether there is no buzzer - not on the inside back as per M5 Stick C Plus.
                                        • The rear sticker shows a few differences in internal GPIO pin allocations.
                                        The twitter post @gavin67890 linked to says its been delayed due to some further changes though.
                                        • E Offline
                                          erich
                                          @bazman thanks!
                                            korffr
                                            Hi Everyone,
                                            I am using an M5Stack CoreS3 and UIFlow2 Alpha-27.
                                            I am new to ESP32 and M5Stack, so not sure if this is a bug in UIFlow2, MicroPython, or it is expected behavior and my understanding of the way it should work is incorrect... :-)
                                            I am trying to update labels with values on a regular basis, the label is in front of a rectangle and the background of the label is the same color as the foreground of the rectangle.
                                            However, it seems that when I update the label text, and the length of the text is smaller than the previous length, it leaves an empty space at the back of the label with the background color. I.e., it does not re-render the 'missing part' of the rectangle.
                                            I could redraw the rectangle after the update, but then the rectangle will overwrite the text.
                                            I could redraw the rectangle and then rewrite the text, but if the value has not changed, it will not write it on the screen and it remains hidden.
                                            The only way to do it is to make the label text empty, draw the rectangle, and then fill the label text with the new value.
                                            That seems like a lot of work just to update a single text label, it also sometimes introduces a flicker (I have quite a number of labels to update)
                                            Is this a bug ? And is there any way around this (without having to clear and redraw all the screen elements one-by-one)?
                                            Here is a minimum program to show the issue:
                                            And the output:
                                            Richard
