    Problem about M5stack GPS
    4 Posts 3 Posters 11.4k Views 1 Watching
      ken57093
      I'm trying to use M5Stack GPS now and I have a problem.I tried the example from the arduino Examples/Modules/FullExample. I had tried a few days still cannot fix the problem.
      And the outcome in the M5Stack is "No GPS data received: check wiring".Is that mean my GPS can't get data? How can I fix it?
      Thanks a lot!
      • lukasmaximusL Offline
        @ken57093 From your picture it looks like the baud rate maybe set wrong on your serial monitor. It should be 115200 baud
          ken57093
          @lukasmaximus Thanks a lot!
          I can see the data in serial monitor now. But in my M5Stack, it still show that "No GPS data received: check wiring". Do you have any idea?
            claus
            The gpsmodul is from Navspark and the output is not equal NMEA .
            Sample: $GNRMC but not $RMC.
            The libraries TinyGPS++ and TinyGPS can not work with the output.
