M5Stick
 hi, is wifi available in m5stick ?
 @ederle
 Yes, all M5 primary modules have wifi as its built into the esp32.
 Yes and now its possible to program some basic functionality of the stick in Uiflow, make sure to download the stick specific version of firmware 1.0.1 if you want to try
 thank you for your reply :-)
 @lukasmaximus thank you for your reply
 @lukasmaximus
 In your reply above you mentioned firmware 1.0.1 for the stick but in the M5-burner download it only has version 1.0 of the uiflow firmware for the M5stick. Can you please verfiy which firmware is the most recent. Also will the MPU9250 work with the M5stick in uiflow. thanks
