where is the wait block gone in Uiflow 2.0
for example if I want to add affection tp wait for 20ms
Hi @m5picoman
If you need delay function, you need add the time form software. Then you will see the sleep block, you can use this.
It has been moved to the Time functions.
Thanks both. Is there a documentation for UIFlow 2.0 you can share?
Its in the process of being written.
