    Load images on M5Paper in UIFlow
    12 Posts 7 Posters 18.6k Views
      Hello @fr3nd
      have you tried to display the default.jpg? Does that work?
      Using UIFlow 1.8.7 (https://flow.m5stack.com) these are the steps which worked for me:
      • drag image icon onto screen (e.g. image0)
      • block set screen show
      fr3ndF 1 Reply Last reply Reply Quote 0
      • fr3ndF Offline
        fr3nd @felmue
        Hi @felmue
        This works with the default image default.png, but once I upload a different one it shows the exclamation mark symbol.
        I've tried with different formats and options when saving, but I haven't found a combination that works. Is there any documentation on the requirements of the images? Has anyone had any success using custom images in m5paper in uiflow?
          Hello @fr3nd
          sorry, I don't know of any documentation on the requirements of the images.
          • fr3ndF Offline
            fr3nd
            For the record, I was finally able to generate images that load properly with the following ImageMagick command:
            convert image.png -colorspace RGB -depth 8 -colors 16 PNG8:exported/image.png
              ajb2k3 @fr3nd
              @fr3nd I was just about to say that it is an issue with the way the image is saved.
              I started making a document here :https://github.com/Ajb2k3/UIFlowHandbook/blob/master/En-Coreink-V2.pdf
                doragasu
                This is a bit late, but today I was trying to display images in M5Stack Fire module, and had the same problem. After a bit of trial and error, I discovered that if the PNG file names are long, this error will trigger. And it is not easy to guess that the long file name caused it!
                  This is a limit of the filesystem formatting.
                  • 7 Offline
                    7ames
                    I know this is an older thread but it really saved me! I downloaded GIMP (latest version is currently 2.10.34) and by exporting a PNG, Turning all checks off and compression level to 9 (max) and then pixelformat to 8bpc RGB. With a small filename the image will appear in the UI Flow workspace and on the M5 stick C Plus.
                    I couldnt get Photoshop, Aseprite and even Paint to get anything in UI flow. But GIMP worked just fine.
                    Hope this helps someone else down the road.
                      ajb2k3 @7ames
                      @7ames I have used GIMP since 1999 and used it in my guide document. Glad you worked it out.
                      • X Offline
                        Xiong_M5Stack @fr3nd
                        @fr3nd the picture must be less than 50kb
                          mtylerjr
                          I just got my M5Paper today, so this is very timely info for me, thanks!
