    Convert string to hex
    3 Posts 2 Posters 3.6k Views
      shahabdhafiz
      Hi all..
      I am using M5Stack Core 2. Anyone can help me on converting string to hex. I got string from the uart and I want to convert them to hex value. I couldn't find on how to do it in Blocky or in micropython. One of the example I follow on youtube can't be used. The link is https://www.youtube.com/watch?v=SHylh5iaVXI
      • IAMLIUBOI Offline
        IAMLIUBO
        hi @shahabdhafiz
        You can try this way:
        a = "0x0A"
        b = int(a, 16)
        print(b)
        docs is here: link
          shahabdhafiz @IAMLIUBO
          @iamliubo hi, thanks for the reply.
          I managed to do the example from what you gave and I got the results as it is. but, after several checking, I received bytes from the uart. Then, I need to convert to hex. the method i used is:
          hexVal = hex(int.from_bytes(serData, "big"))
          label14.set_text(str(hexVal)) //to show the hexVal to the label
          I got the idea from the example you gave and THANK YOU so much for that =)
