    m5flow version 1.0.0 issues opening previously saved files
    FAQS
    6
    13
    23.1k
    • lukasmaximusL
      Hi Jpilarski,
      Sorry for the inconvenience and thanks for pointing this issue out. We are aware of the problem
      and are working on a fix to support legacy files which will be out in the next few days. Thanks for the
      support any comments or suggestions for improvement? What do you mean by samples? examples?
      • J
        jpilarski
        The samples I was referring to was the 4 or 6 files you had previously provided in uiflow. I believe you were building a collection of sample files accessible through the interface for educational use. I know there was a weather example ( this was the first sample), recently you added a neopixel example, a remote example and a few other examples but I no longer see links to them in version 1.0.0
        • lukasmaximusL
          Got you
          They will be back for sure don't worry, its just a temporary thing due to a rearranging of the interface
          likely in the next few days or next week they will be back and we will be adding more examples
          • K
            kimo
            I had a similar problem trying to open older files, with the blocks displaying in a broken way. I found that I had renamed them, and naming them back after the convention main_0000000000000.m5f caused them to load correctly.
            • world101W
              world101
              Is there a new firmware for 1.0.0? I was previously using v0.9.0 and I can no longer get Flow to connect to my m5stack. I see the API KEY and the dot is green in the upper right corner of the UI, but I'm just getting this message when trying to upload:
              "Upload code failed, maybe your device is offline check it and retry."
              The firmware here is really old: https://github.com/m5stack/M5Cloud/tree/master/firmwares
              • H
                heybin
                hello, you can download on http://flow.m5stack.com/ setting
                • world101W
                  world101 @heybin
                  @heybin 在 m5flow version 1.0.0 issues opening previously saved files 中说:
                  I'm on a Mac and it's not working for me.
                  I download the zip and extract it. I get this error.
                  Looking at the package contents, the firmware only goes up to v0.8.2 in the file M5Burner_MacOS.zip
                  Please update it with the latest firmware so I can flash v1.0.
                    ajb2k3 @world101
                    @world101 在 m5flow version 1.0.0 issues opening previously saved files 中说:
                    I'm also getting the damaged error.
                    • lukasmaximusL
                      Hi guys I just had the link updated to mac burner with firmware v1.0. The damaged error is actually an issue related to os high sierra and mojave new versions blocking apps from 3rd party developers, open a terminal and input this command to resolve it: sudo spctl --master-disable.
                      A mac burner which will auto-update to the latest firmware and is compatible with all current OS without needing to change anything is being worked on but progress is slow, sorry about this guys hopefully it will be ready before the end of the month.
                      world101W ajb2k3A 2 Replies Last reply Reply Quote 0
                      • world101W
                        world101 @lukasmaximus
                        @lukasmaximus
                        Thanks for the update. After downloading the new file and running the command "sudo spctl --master-disable" in Terminal, M5Burner flashed 1.0.0 successfully. Flow UI is connecting now.
                          ajb2k3 @lukasmaximus
                          @lukasmaximus 在 m5flow version 1.0.0 issues opening previously saved files 中说:
                          I don't have High sierra or mojave!
                          I havent updated in ages and still on Old Sierra
                          • lukasmaximusL
                            lukasmaximus @ajb2k3
                            @ajb2k3 I have updated with the very latest version of the burner which fixes some bugs. Please let me know if it works for you or not.
