    How do you send an HTTP GET or POST in UI Flow
    4 Posts 4 Posters 8.6k Views 1 Watching
      amazingjoe
      I'm still new to the M5 Stick C that I bought. I can see MQTT which is super cool and am hoping there is a way to produce HTTP Requests via GET/POST etc... Is this feature available in UI Flow? Do I need to load a custom library, program it in Python etc...?
      What are my options?
        ajb2k3 @amazingjoe
        @amazingjoe said in How do you send an HTTP GET or POST in UI Flow:
        @LUKASMAXIMUS made a guide to this and shared it on Hackster.io
        M5Stack MicroPython Simple Web Server
        I hope this helps.
        • E Offline
          EBKsuper @ajb2k3
          @ajb2k3 so, what if you are in UIFLOW BLOCKLY mode ? Also the UIFLOW guides are not helping at all.
          I recognized that in general all their "documentation" reads like: "yellow is a colour yellow". They absolutely dont explain nothing at all.
          for the "HTTP REQUEST" function what is expected in the "headers" or "data" column?
          X 1 Reply Last reply Reply Quote 1
          • X Offline
            xiaokutou @EBKsuper
            @ebksuper
            Hi bro, I'm having the same problem. That's why I am here and noticed that you are having the same problem.
            After a few hours of trying, I finally got the data I wanted. I would like to share my solution here. Maybe it will help you, or not, either way, it's worth a try.
            POST example
