    M5Core3 Factory Test
    16 Posts 6 Posters 20.8k Views 1 Watching
      ajb2k3 @sheepDog
      @sheepdog The factory source code is not UIFlow, the factory was written in ardunio. and the source for the compiled firmware in M5Burner should be at that GitHub link.
        sheepDog
        @ajb2k3 The factory source is not at the GitHub link " https://github.com/m5stack/M5CoreS3" or I didn't found it. I found their only utilities and little (!) examples, but not the whole "factorytest.ino"
          mwjk
          Any update on when the Factory Test code will be available ? Love this new Dev Kit!
          THX
            Hello @sheepDog
            I've put together some code which takes the camera picture and puts it onto the LCD of the M5CoreS3. You can find it here.
              sheepDog
              Hallo @felmue,
              nice to meet you here again. What software did you use for your example? "Arduino IDE 2.1.0" and library "M5Stack V2.07."?
                Hello @sheepDog
                I am not an Arduino IDE user. I use VSCode and PlatformIO. So all I can tell you is that I use the latest Arduino Espressif Framework. E.g.
                framework-arduinoespressif32 @ 3.20009.0 (2.0.9)
                It is unfortunate that the version number of the Arduino IDE is almost similar and also the hardware revision of the M5Stack is close. As it is creating a lot of confusion.
                If I am correct then:
                • Arduino IDE 2.1.0 is solely the version of the IDE and does not per se say anything about which Arduino Espressif framework version is used.
                • M5Stack V2.07 is the latest hardware revision M5Stack is selling.
                  sgu @UKTechguy
                  @uktechguy
                  correct. That's called product placement.
                  No matter if the software is avaialble, ripe or not.
                  There are other new products with the ESP32 S3 pushed on the market, also without software support or only with a small demo app.
                    sheepDog @sgu
                    @sgu
                    Yes, this is pure product placement with a few simple examples.
                    I use the Arduino IDE 2.1.0 and this standards:
                    • Additional boards manager URL: https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/arduino/package_m5unified_index.json
                    • M5Stack Library: M5Stack from M5Stack, Version 2.07 (according to the description it should work with M5CoreS3:"Boards included in this package: ..., M5Stack-Core3,..." )
                    • Program with "#include <M5CoreS3.h>"
                      -> The error is:
                    "/Users/*/M5Core3/CamToLCD/CamToLCD.ino:6:10: fatal error: M5CoreS3.h: No such file or directory
                    compilation terminated.
                    I looked at the Library at directory "/Users/*/Library/Arduino15/staging/libraries" and found no M5Core3-Code-patterns!
                      Hello @sheepDog
                      you'll need to download / install the M5CoreS3 library into you IDE. (Not sure how this is done in Arduino IDE though.)
                        sheepDog
                        Hello @felmue,
                        I know the part M5CoreS3 Library and the examples. With some effort I would get it working for the Arduino IDE, but this means a lot of manual work.
                        I am looking for a working environment for easy examples.
