    Unknown board ID 'm5stack-stamps3'
    ESP - IDF
    9.4k
    • I
      Ilkka
      Hi, I try to make a new esp-idf project for Stamp S3. But it comes the following error:
        Hello @Ilkka
        creating such a project worked for me - this is the platformio.ini content that was created:
        [env:m5stack-stamps3]
        platform = espressif32
        board = m5stack-stamps3
        framework = espidf
        So the board m5stack-stamps3 is available.
        • Have you checked all components are up-to-date?
        • Have you checked there is enough free space on the disk?
        • I
          Ilkka
          Hi Felix,
          I am not sure if everything is OK but I reinstalled esp-idf framework again.
          It works with some other Esp32-S3 boards.
          This is my platformio.ini:
          framework = espidf
          And here some messages when trying to compile:
          • list itemExecuting task: C:\Users\XXX.platformio\penv\Scripts\platformio.exe run --environment m5stack-stamps3
          Processing m5stack-stamps3 (platform: espressif32; board: m5stack-stamps3; framework: espidf)
          Error: Unknown board ID 'm5stack-stamps3'
          • The terminal process "C:\Users\XXX.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'm5stack-stamps3'" terminated with exit code: 1.
          • list itemTerminal will be reused by tasks, press any key to close it.
            Hello @Ilkka
            hmm, not sure what's going wrong here. Maybe there is a difference between different computer platforms? You seem to be on Windows and I ran my test on Linux and I do not have access to a Windows machine. Sorry.
            • I
              Ilkka
              Hi Felix,
              Thank your for your help. The most important is to hear that your system is working. I should have a Linux based development environment too.. I will make it.
              BR, Ilkka
              • I
                Ilkka
                Hi, I just tested quickly.. AtomS3 is OK; the project can be created and compiled.
                [env:m5stack-atoms3]
                board = m5stack-atoms3
                framework = espidf
                • I
                  Ilkka
                  Hi, this issue was solved. Easy and logical way:
                  VScode > PlantformIO home > plantforms > update
