    What is the best orientation of M5Stack Atom-lite to get better RSSI?
    PRODUCTS
    2.8k
    • P
      PaulChainKang
      I tried to figure out how to position my Atom-lite for getting better RSSI. When I place the Atom-lite on the table, with the LED and button facing up, the 3D antenna is facing down. I am not sure is this good for practical applications? I tried different orientations on the same position, the deviation of RSSI is under 2dB which maybe caused by the noise. I really appreciate someone can enlighten me.
        Hello @PaulChainKang
        there was a discussion a while ago about WiFi and poor RSSI.
        • P
          PaulChainKang
          @felmue Hi Felix,
          Thank you for pointing me the discussion. It does provide valuable information, however, it doesn't discuss about the orientation of the antenna.
          I am curious that in your applications, how do you usually position the 3D antenna? My WiFi router has three whip antennas all positioned vertically, is putting Atom-lite LED/button up (3D antenna facing down) a good practice?
          Paul
