M5 Matrix Newbie Setup - Always just flashing Green
 Hi, Followed this https://docs.m5stack.com/en/quick_start/atom/uiflow Trying to setup AP mode but its always just flashing green never goes to yellow what could be up? Installed UIFlow_Matrix latest version (online not offline) Txs
 If you just need the API Key, just connect it to your computer, open M5Burner, and select āconfigurateā button under the AtomMatrix firmware, select the serial port atom matrix is connected to, and it will show your API key on the next screen. To get to AP mode you need to plug in/turn on the atom while holding the button under the matrix until it turns yellow.
