    Can't subscribe to MQTT topic
    15 Posts 6 Posters 19.6k Views
    • O Offline
      Oskars
      Can anyone demonstrate the example for subscribing to certain MQTT topic? All I'm getting is an error: "'NoneType' object has no attribute 'subscribe'". Meanwhile publishing to MQTT works as it should.
        What hardware and software are you using as that’s a hardware base error
        • O Offline
          Oskars
          Hardware used is Atom S3, software - UiFlow2.
          My UiFlow2 code:
          Without "MQTT subscribe" block all else works.
          Error when running on device:
          Python code generated by UiFlow:
          import os, sys, io
          import M5
          from M5 import *
          from umqtt import *
          circle0 = None
          mqtt_client = None
          def mqtt_mqttDebugIncoming_event(data):
          global circle0, mqtt_client
          circle0.setColor(color=0x009900, fill_c=0x009900)
          def setup():
          mqtt_client.subscribe('mqttDebugIncoming', mqtt_mqttDebugIncoming_event, qos=0)
          M5.begin()
          circle0 = Widgets.Circle(62, 62, 50, 0xffffff, 0xffffff)
          mqtt_client = MQTTClient('mqttDebug', 'homeassistant.local', port=1883, user='mqttdebug', password='mqttdebug', keepalive=300)
          mqtt_client.connect(clean_session=True)
          mqtt_client.publish('mqttDebugOutgoing', 'This works, broker receives message!', qos=0)
          circle0.setColor(color=0x3333ff, fill_c=0x3333ff)
          def loop():
          M5.update()
          if name == 'main': # Forum message formatter messes this up
          try:
          setup()
          while True:
          loop()
          try:
          print_error_msg(e)
          except ImportError:
            Well that explains it. MQTT in UIFlow is a bit broken as UIFlow2 is for testing only
            • O Offline
              Oskars @ajb2k3
              @ajb2k3In that case, is there an option to use UIFlow with S3 while UIFlow2 is "for testing only"? I did not see any warnings saying "things will not work" while buying it. Is there any timeframe when the already enabled functionality might work? I'm currently not asking about new features or support for more hardware, just for the things that already are available in UI.
              • felmueF Online
                Hello @Oskars
                FWIW: global variable mqtt_client is used in setup to subscribe before it is initialized. Unfortunately in UIFlow2 the Python tab is non functional yet, so the sequence cannot be fixed on the fly.
                • O Offline
                  Oskars @felmue
                  @felmue Thank You, after I changed the code via Thonny and moved mqtt_client.subscribe after initialization the error disappeared. However the device still does not react to MQTT topics it has subscribed. So the bug is not only in UIFlow2 (incorrectly placed subscribe call) but also in MQTT library or firmware?
                    alwa123
                    Any news here?
                    • felmueF Online
                      Hello guys
                      just tested again. MQTT subscribe is still broken for me in alpha 14. Please fix.
                      U 1 Reply Last reply Reply Quote 1
                      • U Offline
                        UKTechguy @felmue
                        @felmue Somewhat annoying that so much seems to be broken at the moment. We have no buttons and I cannot work out how to do anything with the microsd card. Would like to play a wav alarm file when specific MQTT message is received. Neither seems possible yet.
                          Its is still alpha so not the finale item and ma have code changed.
                          U 1 Reply Last reply Reply Quote 0
                          • U Offline
                            UKTechguy @ajb2k3
                            @ajb2k3 It would be good if M5stack had some sort of chart or spreadsheet that stated what currently worked and what didn't. Also an eta for things coming etc. Compared with the number of M5stack youtube "how to" videos that appeared for previous "Core" products, the CoreS3 is suffering. Maybe I got on the Core2/Fire bandwagon after most teething troubles were fixed and most features were no longer "Alpha"!
                            • O Offline
                              Oskars
                              MQTT topic subscribe still seems to be not working in Alpha 16 - no error but no activity on message receiving either. Anyone else has the same issue?
                              • lbuqueL Offline
                                lbuque
                                @Oskars
                                version: Alpha-17
                                import os, sys, io
                                import M5
                                from M5 import *
                                from umqtt import *
                                label0 = None
                                label2 = None
                                label1 = None
                                label3 = None
                                mqtt_client = None
                                def mqtt_testtopic_event(data):
                                  global label0, label2, label1, label3, mqtt_client
                                  label0.setText(str(((str('Topic:') + str((data[0]))))))
                                  label1.setText(str(((data[1]).decode())))
                                def mqtt_testtopic1_event(data):
                                  label2.setText(str(((str('Topic:') + str((data[0]))))))
                                  label3.setText(str(((data[1]).decode())))
                                def setup():
                                  M5.begin()
                                  label0 = Widgets.Label("Text", 4, 3, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
                                  label2 = Widgets.Label("Text", 4, 55, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
                                  label1 = Widgets.Label("Text", 4, 29, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
                                  label3 = Widgets.Label("Text", 3, 81, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
                                  mqtt_client = MQTTClient('umqtt_client', '192.168.2.50', port=1883, user='m5stack', password='m5stack', keepalive=0)
                                  mqtt_client.subscribe('testtopic', mqtt_testtopic_event, qos=0)
                                  mqtt_client.subscribe('testtopic1', mqtt_testtopic1_event, qos=0)
                                  label0.setFont(Widgets.FONTS.DejaVu12)
                                  label1.setFont(Widgets.FONTS.DejaVu12)
                                  label2.setFont(Widgets.FONTS.DejaVu12)
                                  label3.setFont(Widgets.FONTS.DejaVu12)
                                def loop():
                                  M5.update()
                                  mqtt_client.wait_msg()
                                if __name__ == '__main__':
                                  try:
                                    setup()
                                    while True:
                                      loop()
                                    try:
                                      print_error_msg(e)
                                    except ImportError:
                                test_mqtt.m5f2
                                {"version":"V2.0","type":"atoms3","components":[{"name":"screen","type":"screen","layer":0,"screenId":"","screenName":"","id":"__atoms3_screen","createTime":1681463262614,"x":0,"y":0,"width":280,"height":280,"backgroundColor":"#000","size":0},{"name":"label0","type":"label","layer":1,"screenId":"builtin","screenName":"","id":"v^k&_0&lzY#a-pVu","createTime":1681787932237,"x":4,"y":3,"color":"#ffffff","backgroundColor":"#222222","text":"Text","engine":"gfx","font":"Widgets.FONTS.DejaVu18","rotation":0},{"name":"label1","type":"label","layer":2,"screenId":"builtin","screenName":"","id":"lg-u6bmP&KAb-BFg","createTime":1681787940036,"x":4,"y":29,"color":"#ffffff","backgroundColor":"#222222","text":"Text","engine":"gfx","font":"Widgets.FONTS.DejaVu18","rotation":0},{"name":"label2","type":"label","layer":1,"screenId":"builtin","screenName":"","id":"m+Am3fMqYyQ$+VEm","createTime":1681788301006,"x":4,"y":55,"color":"#ffffff","backgroundColor":"#222222","text":"Text","engine":"gfx","font":"Widgets.FONTS.DejaVu18","rotation":0,"width":37,"height":20},{"name":"label3","type":"label","layer":2,"screenId":"builtin","screenName":"","id":"fj^rW#mTo@K0dL5r","createTime":1681788303358,"x":3,"y":81,"color":"#ffffff","backgroundColor":"#222222","text":"Text","engine":"gfx","font":"Widgets.FONTS.DejaVu18","rotation":0,"width":37,"height":20}],"resources":[{"software":["mqtt"]}],"units":[],"hats":[],"i2cs":[],"blockly":"<block type=\"basic_on_loop\" id=\"loop_block\" deletable=\"false\" x=\"490\" y=\"70\"><mutation isUpdate=\"true\"></mutation><field name=\"UPDATEOP\">true</field><statement name=\"FUNC\"><block type=\"system_m5_update\" id=\"system_m5_update\"><next><block type=\"mqtt_wait_msg\" id=\"T1rVj/Q%g){|@a=eic@f\"></block></next></block></statement></block><block type=\"basic_on_setup\" id=\"setup_block\" deletable=\"false\" x=\"130\" y=\"110\"><mutation isBegin=\"true\"></mutation><field name=\"UPDATEOP\">true</field><statement name=\"FUNC\"><block type=\"system_m5_begin\" id=\"system_m5_begin\"><next><block type=\"mqtt_set_client\" id=\"g+(|o=#m4jpn7OLPkw)J\"><value name=\"ID\"><shadow type=\"text\" id=\"?[M!b8*f#bx*SpMXH!!5\"><field name=\"TEXT\">umqtt_client</field></shadow></value><value name=\"SERVER\"><shadow type=\"text\" id=\"oNzSR(TF-,inxj~YS2}#\"><field name=\"TEXT\">192.168.2.76</field></shadow></value><value name=\"PORT\"><shadow type=\"math_number\" id=\"e~GXuZ!~qfASA;IYe3f=\"><mutation max=\"Infinity\" min=\"-Infinity\" precision=\"0\"></mutation><field name=\"NUM\">1883</field></shadow></value><value name=\"USER\"><shadow type=\"text\" id=\"3PbUi]|zTswyRzP*h=Zm\"><field name=\"TEXT\">m5stack</field></shadow></value><value name=\"PASSWORD\"><shadow type=\"text\" id=\"d.(iU%~um%@j5=N8C!9:\"><field name=\"TEXT\">m5stack</field></shadow></value><value name=\"KEEPALIVE\"><shadow type=\"math_slider\" id=\"4lCv3Yqkt^hJHwEHH,R)\"><mutation max=\"65535\" min=\"0\" step=\"1\" precision=\"1\"></mutation><field name=\"NUM\">0</field></shadow></value><next><block type=\"mqtt_connect\" id=\"N$GCr?UqrYp~!@[yZfZ~\"><field name=\"CLEAN\">True</field><next><block type=\"label_set_font\" id=\"sBjX6,JwP2hIWbkZU]#L\"><field name=\"NAME\">label0</field><field name=\"FONT\">Widgets.FONTS.DejaVu12</field><next><block type=\"label_set_font\" id=\"l{(uGTFfhsb)s(6iS/hU\"><field name=\"NAME\">label1</field><field name=\"FONT\">Widgets.FONTS.DejaVu12</field><next><block type=\"label_set_font\" id=\"Rn6r~[cLiSQf+]nM8sTq\"><field name=\"NAME\">label2</field><field name=\"FONT\">Widgets.FONTS.DejaVu12</field><next><block type=\"label_set_font\" id=\"oaK+AUCEaQtl@kR^|jP;\"><field name=\"NAME\">label3</field><field name=\"FONT\">Widgets.FONTS.DejaVu12</field></block></next></block></next></block></next></block></next></block></next></block></next></block></statement></block><block type=\"mqtt_subscribe\" id=\"w7Ov@_:I,|/99:[91gQ+\" x=\"90\" y=\"570\"><value name=\"MSG\"><shadow type=\"text\" id=\"5+0D;yAI;M9Kab.KdV([\"><field name=\"TEXT\">testtopic</field></shadow></value><statement name=\"FUNC\"><block type=\"label_set_text\" id=\"qN{uc|lEU4,^0u_YYo@7\"><field name=\"NAME\">label0</field><value name=\"TEXT\"><shadow type=\"text\" id=\"5~k^hoGX6L}naX9o!pt=\"><field name=\"TEXT\">Label</field></shadow><block type=\"text_add_str\" id=\"tAsN]8zdz!{wa]J5fQRj\"><value name=\"VALUE1\"><shadow type=\"text\" id=\"NTGIBKM?0;M)9Q$?/F/E\"><field name=\"TEXT\">Topic:</field></shadow></value><value name=\"VALUE2\"><block type=\"mqtt_get_topic\" id=\"O)j9sIdBDlw?k(Y4#E{]\"></block></value></block></value><next><block type=\"label_set_text\" id=\"AIj|L5*V}(Na=i~]!Wr{\"><field name=\"NAME\">label1</field><value name=\"TEXT\"><shadow type=\"text\" id=\"9gNvISVfV@]35[tz`S6-\" disabled=\"true\"><field name=\"TEXT\">Label</field></shadow><block type=\"text_decode_str\" id=\"}[Ilzb9o=Qd12AOz*Q/k\"><value name=\"VALUE\"><block type=\"mqtt_get_msg\" id=\"p48aW7MN4QcC/]H_RqLv\"></block></value></block></value></block></next></block></statement></block><block type=\"mqtt_subscribe\" id=\":g;Bc#f6bCJv3D=P,C24\" x=\"690\" y=\"550\"><value name=\"MSG\"><shadow type=\"text\" id=\"p!BP(rRWfzb8%w2;)|Z/\"><field name=\"TEXT\">testtopic1</field></shadow></value><statement name=\"FUNC\"><block type=\"label_set_text\" id=\"+{@FB5tyv:a,[(0)S^?^\"><field name=\"NAME\">label2</field><value name=\"TEXT\"><shadow type=\"text\" id=\"5~k^hoGX6L}naX9o!pt=\"><field name=\"TEXT\">Label</field></shadow><block type=\"text_add_str\" id=\"MOXaUlFRx59,!q}DPD;6\"><value name=\"VALUE1\"><shadow type=\"text\" id=\"ABnF09VK)vlEkGQ|B9P*\"><field name=\"TEXT\">Topic:</field></shadow></value><value name=\"VALUE2\"><block type=\"mqtt_get_topic\" id=\"3w2H7IRX7ZEIXgo$ZPFE\"></block></value></block></value><next><block type=\"label_set_text\" id=\"sAd`+qhCgZXd{Kt,+h$r\"><field name=\"NAME\">label3</field><value name=\"TEXT\"><shadow type=\"text\" id=\"9gNvISVfV@]35[tz`S6-\" disabled=\"true\"><field name=\"TEXT\">Label</field></shadow><block type=\"text_decode_str\" id=\"(3lEfMbcJYt7tw_fl=%3\"><value name=\"VALUE\"><block type=\"mqtt_get_msg\" id=\"YAAO(q1I]VjM1vGhYh2R\"></block></value></block></value></block></next></block></statement></block>","screen":[{"simulationName":"Built-in","type":"builtin","width":128,"height":128,"scale":1.3,"screenName":"","blockId":"","id":"builtin","createTime":1681463262611}]}
                                O 1 Reply Last reply Reply Quote 2
                                • O Offline
                                  Oskars @lbuque
                                  @lbuque Thanks a million to You, I finally got the code working! Looks like the thing I was missing was to use "MQTT apply for messaging" block in the loop. And changing the default 0 keepalive value (after some searching I found it caused problems with my Mosquitto broker).
