    Failed to use CAN with M5Stack
    PRODUCTS
    9.8k
    • H
      Hayashi
      返信: M5Stack with CAN
      I tried the follow library, changed pin to GPIO17/16
      https://github.com/nhatuan84/arduino-esp32-can-demo
      But it does not work. I used oscilloscope to check the output from pin GPIO 17/16, There is no any output.
      Could someone give me an example code that works, and a picture of connection.
      Thanks!
      • m5-docsM
        m5-docs @Hayashi
        @hayashi
        Hi hayashi
        I want to confirm which module you used?
        Is that one?
        https://www.aliexpress.com/store/product/M5Stack-New-COMMU-Module-Extend-RS485-TTL-CAN-I2C-Port-with-MCP2515-TJA1051-SP3485-Development-Board/3226069_32954475633.html?spm=a2g1y.12024536.productList_5885011.subject_1
        M5Stack documentation URL
        https://docs.m5stack.com
        • H
          Hayashi @m5-docs
          @watson
          I didnot use any extend module, only connect M5Stack to a CAN-tranceiver. Also I am going to buy that module. Could you tell me how to use that module?
          m5-docsM 2 Replies Last reply Reply Quote 0
          • m5-docsM
            m5-docs @Hayashi
            @hayashi
            I have some test program about thisCOMMU module. Recently, I'll add those example codes to m5stack's documentation.
            • H
              Hayashi @m5-docs
              @watson
              Thank you, please inform me if you upload that sample codes.
              I have another question, why there is a CAN controller MCP2515 on the extend module? Does not M5STACK include CAN controller?
              • m5-docsM
                m5-docs @Hayashi
                @hayashi
                Hey, here's the example about CAN.
                https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Module/COMMU/Arduino/CAN
