    M5stack Fire setup issues
    2 Posts 2 Posters 5.9k Views 1 Watching
      roadfox
      Hi
      Just got an m5stack fire and was able to connct him to wifi.
      Now a barcode is shown and if a ifollow that link i end on the m5go.com webpage.
      But on that webpage my fire is lways shown as offline:
      ID ( xxxx ) : Offline
      I do not have a firewall or something special.
      The Serial output looks ok:
      ets Jun  8 2016 00:22:57
      rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:2
      load:0x3fff0018,len:4
      load:0x3fff001c,len:4848
      ho 0 tail 12 room 4
      load:0x40078000,len:7436
      load:0x40080000,len:7076
      entry 0x40080348
      Internal FS (SPIFFS): Mounted on partition 'internalfs' [size: 2490368; Flash address: 0x1A0000]
      Filesystem size: 2281728 B
                 Used: 932864 B
                 Free: 1348864 B
      Device ID:840d8e258d00
      LCD initializing...Done!
      [6962] State change: STA_STARTUP ===> STA_GUIDE
      [14533] State change: STA_GUIDE ===> STA_CONNECT_WIFI
      ....[WiFi] event: 4 (Station connected to AP)
              info: {'ssid': 'uhu-privat', 'channel': 1}
      .....Connected!
      [16615] State change: STA_CONNECT_WIFI ===> STA_WEB_QRCODE
      [WiFi] event: 7 (Station got IP from connected AP)
              info: {'ip': '10.1.1.117', 'changed': True}
      MicroPython ESP32_LoBo_v3.2.20 - 2018-06-28 on M5Stack with ESP32
      >>> [M5-xxxxyyyyyyyyyyy] M5Cloud connected.
      any idea whats wrong or where i can get support?
      thanks
      andi
      • lukasmaximusL Offline
        Hi roadfox,
        The coding platforms you can connect to (m5go, m5cloud, ui flow) depend on what firmware you have burned
        on your device. For example if you have m5go firmware you cannot connect to the ui flow site with it.
        The firmware can be easily changed/re-flashed by using the burner tools on our website
        for windows http://flow.m5stack.com/download/M5Burner-flow-only.zip
        for mac http://flow.m5stack.com/download/M5Burner_MacOS.zip
        You can follow this youtube guide on how to flash your device if you get stuck
        https://www.youtube.com/watch?v=oEiFLsukAEE
        Hope this helps, let us know if you manage to get setup
