    CAN BUS Error with M5Stack and COMMU Module
    UIFlow
    3.3k
    • E
      elettronico
      Hi, I send the command via canbus to the M5stack but receive a different message.
      Example:
      I send 00 00 00 D8 0D 06 01
      I receive 00 00 00 D8 r 08 01
      It doesn't seem to like '0D' and sees it as CR
      Is this a bug? Any ideas on how to fix it?
      thank you!
      • C
        crapitouille
        I also have a bug with the COMMU module and the CAN BUS.
        The code I have is working with the firmware 1.11.6, but not anymore with the 1.11.7.
        I get the following error message "function takes 4 positional arguments but 3 were given". This is the python command "com.commu_can_init(3, 3)".
        Any update on that ?
        • E
          elettronico
          Solved with the code ;-)
          message = com.commu_can_read_message(0)
          hex_list = []
          for b in message:
          hex_str = hex(b)[2:]
          if len(hex_str) < 2:
          hex_str = '0' + hex_str
          hex_list.append(hex_str)
