    Int to Float conversion
    UIFlow
    6.4k
    • E
      elettronico
      Hello, how can I convert an int value (10000 mV) from a variable to a float value in a Label block (10,000 V) ?
      Thank you all for the help
      • C
        Cognitive5525
        What language?
        In Python you can simply:
        my_val = 10000
        my_val = my_val/1000
        • C
          Cognitive5525
          Since you posted under UIFlow, then that is what you use I suppose:
          which results in the following Python code:
          my_val = my_val / 1000
          • E
            elettronico
            thank you Cognitive5525, I have already tried but it does not work.
            Here is the partial code:
              A3 = (str((hex(A2)[2:] + hex(A1)[2:])))
              A4 = (str(int(A3, 16))) // here all ok and the Label shows 10000 mV
              A5 = A4 / 1000
              label0.setText(str(A5)) //the label shows nothing
            • C
              Cognitive5525 @elettronico
              I'm not sure what A3 becomes since I can't see what A1 and A2 are, but:
              makes A4 a string which you can't do arithmetic on.
              Provided that A3 can be converted to an integer, I would:
              A4 = int(A3, 16)
              A5 = A3 /1000
              • E
                elettronico
                @cognitive5525 said in Int to Float conversion:
                A4 = int(A3, 16)
                A5 = A3 /1000
                Thank you!
                solved with this code:
                A4 = int(A3, 16)
                A5 = A4 /1000
                  Use the math function block to convert in to float then use a text block to convert to string?
