    Don't know what to use
    31 Posts 5 Posters 75.3k Views 3 Watching
      The pinouts are located on the M5Stack product page by following the documents link https://docs.m5stack.com/en/core/basic_v2.6?ref=pfpqkvphmgr
      The exact pins and location depend on the specific model of core but he is using the Core2's MBus which is the big internal connector.
        jerome83136
        Thank you for your feedback.
        As I'm quite new on this kind of stuff (using pins to interact with an external component); I need some tips :)
        When I do this on UIFlow:
        I understand it activates the pin n°2 (LOW), when the "switch0" is activated. Am I right ?
        How can I identify the pin n°2 on my M5 Core basic with a base core bottom ?
        I think I need some documentation/tutorial to understand the correspondance between the pins used into UIFlow and the the pinmap on M5 Core Basic. Can I find this somewhere ?
        Thank you for your help
        Best regards
          jerome83136
          I finally got the relay working with M5 Core Basic !
          I think my mistake was to power the relay with 5v rather than 3.3v
          Here is my wiring:
          And here is the example UIFlow that works for me:
          Now I need to find a way to power the M5 Core Basic by using a DC 12V --> USB 5V connector and connect it to the DC 12V power supply I already use.
          Next step will be the hardest: understanding how PaHub works to interconnect the M5 Core Basic with:
          • RFID reader
          • M5 Scales kit
          • M5 Ultrasonic Distance Unit
          I will report progress here
          Thank you again for your help
          Best regards
            jerome83136
            Hi all,
            Another report here.
            Almost everything is ready.
            I'm quite sure the RFID2 reader won't do the job because of its short reading range; let's try and improve if required.
            I will certainly have to give this reader a try. (already ordered)
            1 question I had while testing: TOF and RFID2 seems to need Ports A or E. But Port E never worked (the unit is seen as "not connected" by the Core); forcing me to use a PaHub which is a pity because I have plenty of available ports with the ExtPort extension.
            Someone able to help me understanding why ? (If I could use port E; I could completely remove the PaHub)
            Here is the current setup:
            Last thing to do to complete the prototype: get a 12v --> 5V USB connector in order to power the M5 Core + 12v DC motor with a single source.
            Here is a simple UIFlow to check every component works correctly:
            Best regards
              jerome83136
              Hello all,
              Last part done (single power supply for M5 core + DC motor)
              I was also able to remove the PaHub by using the ExtPort (Port D). I had to change the dip switch value to:
              • Port D-1[2] = ON (to use GPIO22)
              • Port D-2[2] = ON (to use GPIO21)
              I then had to change the TOF module's port config in UIFlow to use the Port D:
              Final diagram:
              NB: DC(12v) to USB(5v) converter link
              Now let's get physcal parts printed and test it !
              Best regards
                Cool and thanks for sharing your progress.
                When you get everything up and running, please create a build log on Hackster.io
                  jerome83136
                  Hi guys,
                  New problem here: I'm unable to use this RFID reader from Seeed studio
                  The reader is able to communicate by serial (9600 baudrate, 8 data bits, 1 stop bit, and no verify bit)
                  I connected it with my Ext port Blue port PortC (stacked with my M5 Core Basic)
                  • Reader Yellow wire (TX) --> Ext port (Port C) / PIN13
                  • Reader White wire (RX) --> Ext port (Port C) / PIN14
                  On UI Flow I tried this:
                  When I put an RFID tag on the reader; a red led seems to indicate it detects the tag; but I get nothing printed on my M5 Core Basic screen.
                  What did I wong ?
                  Best regards
                    jerome83136
                    Anybody here to help me on this blocking point?
                    Thank you
                    Best regards
                      jerome83136 @ajb2k3
                      @ajb2k3 hello,
                      I would be really happy to share my project; but for this I will need some help on my last question on this topic 😉
                      Any suggestion to unblock me ?
                      Best regards
                        Have you got a micropython library installed for the reader?
                        It looks like you set up the connection but you have yet to initialise the reader and tell it to start talking.
                          jerome83136
                          The code generated by the UIflow example from my last screenshot is the following:
                          from m5stack import *
                          from m5ui import *
                          from uiflow import *
                          setScreenColor(0x222222)
                          lcd.fill(0xffffff)
                          uart1 = machine.UART(1, tx=14, rx=13)
                          uart1.init(9600, bits=8, parity=None, stop=1)
                          while True:
                          if uart1.any():
                          lcd.print((uart1.read()).decode(), 0, 0, 0xff0000)
                          wait_ms(2)
                          Do I need to add something else to this code to receive any signal from the reader ?
                          Do tyou mean UIFlow requires additional libraries to be able to communicate over serial (UART) ?
                          Best regards
                            jerome83136
                            Hello @ajb2k3
                            I took a look on your UIFlow handbook for some examples on serial communication.
                            I found this:
                            It seems the code is almost the same than the one generated for me by UIFlow.
                            The imported libraries are the same than the ones I have in my code:
                            from m5stack import
                            from m5ui import
                            from uiflow import
                            On the example provided by my reader's provider; they import this library: " #include <SoftwareSerial.h>"
                            https://wiki.seeedstudio.com/Grove-125KHz_RFID_Reader/#play-with-arduino
                            But I think this is the implémentation for Arduino and I guess the equivalent UIFlow libraries are loaded through this:
                            from m5stack import
                            from m5ui import
                            from uiflow import
                            Do I miss something ?
                            On my side I think the reader works because when I bring a RFID tag close to it; the status led of the reader lights up.
                            But I still receive nothing on the M5 core RX PIN
                            Best regards
