A few questions about the stepper motor model.
@m5stack Would you mind answering a few questions on the construction of the stepper motor module.
Q1, Where is the arduino?
Q2, are the stepper drivers soldered to the main board? -
Hello ajb2k3,
A1: here is the arduino examplehttps://github.com/m5stack/stepmotor_module/tree/master/Example/StepMotor_M5test
A2: The stepmotor module can be stacked below the main board. They communicate with each other through I2C. The I2C address of stepmotor module is 0x70 by default.
@watson 在 A few questions about the stepper motor model. 中说:
Hello ajb2k3,
Thats not the answers to what I asked.
Ok I will try again.
Q1 where is the Arduino (atmega 328) located on the module.
Q2 Are the Stepper Motor driver's soldered directly to the M5Stepper module PCB? -
A1 here is the document and picture about stepmotor module
https://m5stack.github.io/m5-docs/#/en/product_documents/modules/module_stepmotor
A2 Yes, soldered to PCB
Thanks, I wondered why I could not move them or find the atmega.
Thank you.
