    bluetooth in core2
    Core 2
    5
    8
    13.9k
    • J
      jpilarski
      I've installed core2 beta4. I see ble is listed when I run help('modules'). I notice that I can import ble without an error, however when I run the code that uses ble it reports an error that bluetooth module is not available. It looks like there is plenty of memory available for the module. I am requesting that bluetooth is enabled for core2 uiflow firmware. If there is a way to add the module to the current uiflow firmware I'd welcome the info.
      • J
        jpilarski
        Just checking back to see if and when bluetooth block will be added to core 2 in uiflow. thanks
        • ZontexZ
          Zontex
          Hi jpilarski, super sorry for the late reply. We will release support for BLE in Core2 UI Flow in the next version which will be approximately next week or in 2 weeks.
            shay @Zontex
            @zontex
            Hi, I would also like to follow up on BLE in Core2 UI flow.
            Any update?
            • ZontexZ
              Zontex @shay
              @shay Support was added, you can check
              W A 2 Replies Last reply Reply Quote 0
              • W
                Wolli01 @Zontex
                @zontex Thank You!
                • A
                  alvaroskinoski @Zontex
                  @zontex it looks like there has been an update to Bluetooth on UiFlow for Core2: now it appears BLE Central and BLE peripheral options. Do you know what the difference is?
                  Thanks!
                  Alvaro B.
                  • A
                    alvaroskinoski
