    [SOLVED] Hi All I'm suffering a stupid moment.
    Micropython
    2.2k
      Why is it that this code work on a RPI and An M5Stamp C3 but not and ESp32 Pico D4 found in the stick family running MP1.19.1 (mainstream)?
      # Imports
      import time
      from machine import Pin
      from neopixel import NeoPixel
      # Define the strip pin number (28) and number of LEDs (15)
      strip = NeoPixel(Pin(28), 15)
      # Variable for the fade speed
      delay = 0.005
      while True: # Run forever
          # Iterate from 1 to 255 in steps of 1
          for i in range(1,255,1):
              # Fill the strip using the iterated R value
              strip.fill((i,0,0))
              # Write the data to the LED strip
              strip.write()
              # Delay
              time.sleep(delay)
          # iterate from 255 to 1 in steps of -1
          for i in range(255,1,-1):
              strip.fill((i,0,0))
              strip.write()
              # Delay
              time.sleep(delay)
      Ok solved it. The issue was due to power supply issues.
