    My M5 Stack Fire is Dead or Bricked somehow
    18 Posts 6 Posters 36.1k Views 2 Watching
    • E Offline
      ekalfwonS @ajb2k3
      @ajb2k3 Thanks, I figured out I should use the UFlow 1.4.3. With that burned, I am back to how the Fire was when I bought it. Thanks for the help everyone!
      Now I just need to figure out how to add programs to the list of programs when it starts. How can I add other demos or programs to that list?
        ajb2k3 @ekalfwonS
        @ekalfwons In the setting menu is a download button, this permanently stores it on the M5Stack and is accessible from the menu.
        • E Offline
          ekalfwonS @ajb2k3
          @ajb2k3 I can't find a Settings menu in the Arduino IDE... The Settings in M5Burner just shows the version of M5Burner. Where is this settings menu?
          • SkinkS Offline
            Skink
            @ekalfwonS ,
            this is only possible inUIFlow not in the Arduino software, in UIFlow you see Project in the upper left corner, on the right side you can assign a name for your program. Then go to the far right and select Download by clicking on the last icon. This will save your program as you named it on the M5Stack Fire.
            skink
              ajb2k3 @ekalfwonS
              @ekalfwons said in My M5 Stack Fire is Dead or Bricked somehow:
              the setting are in uiflow not m5burner. sorry.
              • E Offline
                ekalfwonS
                Ah, found it now. Thanks everyone!
                I don't suppose there's a way to bring one of the examples from the Arduino IDE into UIFlow so I could install it alongside the other apps...
                  ajb2k3 @ekalfwonS
                  Nope, Arduino uses a variant of C, UIFlow uses Micropython.
                    ps.oz
                    I have a Core2. Mine was bricked - USB sounded when disconnecting in Windows 10. Only got it brand new yesterday and was using UIFlow, tried everything. In Arduino it could send to COM4 but then still black screen, still no reset. Then someone above said use M5Burner. Eventually reflashed the Core2FactoryTest app and wahey - green light and a beep and now everything works again. I'm adding this comment as I'm a techie for 35 years and if I run into problems like this I'm sure others will with less success.
                    N 1 Reply Last reply Reply Quote 1
                    • N Offline
                      nerdmeeting @ps.oz
                      @ps-oz I'm having the same problem here except when I plug in to my MacBook Pro via USB-C the device and port are no longer listed in UIFlow or M5Burner.
                        ajb2k3 @nerdmeeting
                        @nerdmeeting Have you installed the updated Ch340 drivers
