    UI-Flow: Detect charging via M5GO Battery Bottom2 (with Core2)
    3 Posts 2 Posters 4.1k Views 1 Watching
      AEisele55
      In UIFlow, I want to detect if my M5Core2 is charging on its Battery Base (using the GO Battery Charger)
      Is this possible?
      If I charge it using the USB-C Cable, the Charge State Block detects it, but not using the M5Go-Charger
      Thanks in advance
      Aaron
      M5Core2, M5Atom Matrix + dLight Unit, M5stickCplus
      • felmueF Online
        Hello @AEisele55
        I am afraid that is not possible. The reason is that the M5GO Battery Bottom2 has its own charger IC (TP4057) which only has the two LEDs (red and green) but no way to get the state via software.
        In other words:
        • with the USB-C cable the charger IC (AXP192) from the M5Core2 is used to charge the battery.
        • with the M5GO charger the charger IC (TP4057) in the M5GO Battery Bottom2 is used to charge the battery.
          AEisele55
          OK,
          I'll try and get the voltages (using the data from axp192) when charging and when not charging and see if i can detect it using this.....
          Thanks Aaron
