    I need help with a webserver project...
    25 Posts 2 Posters 105.4k Views 2 Watching
    • RopR Offline
      Rop
      Ah, a backtrace. You can copy paste that whole boot thing into the "ESP Exception Decoder" which you first have to install into the IDE. (Can't do it for you, it needs the compiled binary to work.) This will tell you what chain of routines (both in your own code and in the ESP core) were executing before it crashed. I'll look at your code later...
        CrazyHorse80
        Here it is (totally nonsense for me, remember I'm a noob with ESP):
        Decoding stack results
        0x400907fc: invoke_abort at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/esp32/panic.c line 155
        0x400909d1: abort at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/esp32/panic.c line 170
        0x40081df9: lock_acquire_generic at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/newlib/locks.c line 141
        0x40081f25: _lock_acquire_recursive at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/newlib/locks.c line 169
        0x40118972: _vfprintf_r at ../../../.././newlib/libc/stdio/vfprintf.c line 860
        0x4011bbc5: vprintf at ../../../.././newlib/libc/stdio/vprintf.c line 39
        0x400855ca: esp_log_write at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/log/log.c line 215
        0x400f6872: __assert_func at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/bootloader_support/src/bootloader_init.c line 537
        0x4008def9: vTaskEnterCritical at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/freertos/portmux_impl.inc.h line 105
        0x4008d355: xQueueGiveFromISR at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/freertos/queue.c line 1323
        0x40083bc8: timer_alarm_handler at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/esp32/esp_timer.c line 318
        0x40083e15: timer_alarm_isr at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/esp32/esp_timer_esp32.c line 274
        0x40107757: esp_vApplicationIdleHook at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/esp32/freertos_hooks.c line 64
        I think I'm not understanding how ESP32 works and so it's a lot of pain to write some code for me... I can work with Arduinos which use procedural code, but I'm guessing ESP32 is a totally different thing. Could it be that it has a small operating system that runs in parallel of my own code and I have to write only event driven functions? I need an ESP for dummy book for sure, do you know something easy to start from?
        • RopR Offline
          Rop
          OK, I'm afraid I don't know your code well enough to be of much help, but here's some things I do know or think I know:
          Most errors look harmless (or at least unconnected to your isssue) to me.
          11:23:11.850 -> [E][Preferences.cpp:437] getString(): nvs_get_str len fail: SSID2 NOT_FOUND
          11:23:11.850 -> [E][Preferences.cpp:437] getString(): nvs_get_str len fail: key2 NOT_FOUND
          11:23:11.850 -> [E][Preferences.cpp:306] getUChar(): nvs_get_u8 fail: faces_on NOT_FOUND
          Totally expected behaviour and in no way connected to your problem: M5ez is looking for stuff in NVS when it starts up, some it finds, some it doesn't.
          Querying pool.ntp.org ... [E][WiFiUdp.cpp:170] beginPacket(): could not get host from dns: 11
          21:00:32.992 -> ERROR: Timeout
          If this was sometime after startup, it might point to the M5Stack having intermittent network connectivity.
          I wonder what the other Arduino's view of the world is: does it think it can deliver the message when you don't get it displayed on the M5Stack?
          As for the stack trace: it's a pity it doesn't go back into your code, that would have been more helpful. As it is if I had to wildly guess: does your code do anything that involves a timer? The problem seems to start by time_alarm_isr (the interrupt service routine) being called and then sometime later something being (possibly) unable to acquire a lock on some resource, possibly while writing a log entry. But I don't know the ESP core well myself either... I would recommend setting Core Debug Level to "None", it would not surprise me if that stops these crashes. (And who knows: maybe the core and your program fighting over the serial buffer was the whole problem to begin with...)
            CrazyHorse80
            The only thing I did related to a timer, is using the ez.addevent to call the handleclient function as you suggested in the other thread (actually I enclosed it in a function that returns the interval as you said to do). My program does not a lot other than running m5ez and the simple web server to collect data from the Arduino to display on m5stack... I don't know if I can post the entire code but I can try to...
            The timeout errors happen after few minutes from startup, but the connection seems to be good 'cause I can see the widget with 2 or 3 bars all the time.
            As for what the Arduino does, it sends a request to M5Stack every minute and it tries to send for 5 times if it didn't receive 200 OK response from server. It does that and the error I get on Arduino's side is "no connection", instead on M5Stack I can see nothing arriving (from serial monitor). Every now and then I receive some data but it's not a constant flow.
            Tomorrow I'll do some more tries without core debug...
              CrazyHorse80
              This is the code (it's my first try, be kind! :D):
              #include <M5Stack.h>
              #include <ezTime.h>
              #include <M5ez.h>
              #include <WiFi.h>
              #include <WiFiClient.h>
              #include <WebServer.h>
              #include <ESPmDNS.h>
              #include "images.h"
              #define MAIN_DECLARED
              WebServer rDserver(1980);
              byte   remYear = 0;           // Current PVControl server Year
              byte   remMonth = 0;          // Current PVControl server Month
              byte   remDay = 0;            // Current PVControl server Day
              byte   remHour = 0;           // Current PVControl server Hour
              byte   remMinute = 0;         // Current PVControl server Minute
              float  GenE = 0;              // Last Generated Energy
              float  UseE = 0;              // Last Consumed Energy
              float  TtGE = 0;              // Last to the Grid Energy
              float  FtGE = 0;              // Last from the Grid Energy
              int    GenP = 0;              // Last Generated Power
              int    UseP = 0;              // Last Consumed Power
              int    NetP = 0;              // Last Net Power
                #include <themes/default.h>
                #include <themes/dark.h>
                ezt::setDebug(INFO);
                ez.begin();
                if (ez.wifi.indexForSSID("xxx") == -1) {
                  ez.wifi.add("xxx", "xxx");
                  ez.wifi.writeFlash();
                MDNS.begin("remdisplay1");
                rDserver.on("/", handleRoot);
                rDserver.onNotFound(handleNotFound);
                rDserver.begin();
                dacWrite(25,0); // Speaker mute
                ez.addEvent(serveClients, 3000);
                ezMenu mainmenu("remDisplay");
                //  mainmenu.txtSmall();
                mainmenu.addItem("PVControl", remDisplay);
                mainmenu.addItem("Settings", mainmenu_image);
                //  mainmenu.addItem("Updates via https", mainmenu_ota);
                mainmenu.upOnFirst("last|up");
                mainmenu.downOnLast("first|down");
                mainmenu.run();
              uint16_t serveClients() {
                rDserver.handleClient();
                return 500;
              void handleRoot() {
                rDserver.send(200, "text/plain", " OK");
                for (uint8_t i = 0; i < rDserver.headers(); i++) {
                  Serial.print(" ");
                  Serial.print(rDserver.headerName(i));
                  Serial.print(": ");
                  Serial.println(rDserver.header(i));
                for (uint8_t i = 0; i < rDserver.args(); i++) {
                  Serial.print(" ");
                  Serial.print(rDserver.argName(i));
                  Serial.print(": ");
                  Serial.println(rDserver.arg(i));
                if(rDserver.args() == 7) {
                    if((rDserver.argName(0) != "r") || (rDserver.argName(1) != "da")
                      || (rDserver.argName(2) != "ti") || (rDserver.argName(3) != "v1")
                        || (rDserver.argName(4) != "v2") || (rDserver.argName(5) != "v3")
                          || (rDserver.argName(6) != "v4")) {
                      return;
                    else {
                      remYear = atoi(rDserver.arg(1).substring(0,3).c_str());
                      remMonth = atoi(rDserver.arg(1).substring(4,5).c_str());
                      remDay = atoi(rDserver.arg(1).substring(6,7).c_str());
                      remHour = atoi(rDserver.arg(2).substring(0,1).c_str());
                      remMinute = atoi(rDserver.arg(2).substring(2,3).c_str());
                      GenE = atoi(rDserver.arg(3).c_str());
                      GenP = atoi(rDserver.arg(4).c_str());
                      UseE = atoi(rDserver.arg(5).c_str());
                      UseP = atoi(rDserver.arg(6).c_str());
                      NetP = GenP - UseP;    // Last Net Power
                      remDisplay();
              void handleNotFound() {
                String message = "File Not Found\n\n";
                message += "URI: ";
                message += rDserver.uri();
                message += "\nMethod: ";
                message += (rDserver.method() == HTTP_GET) ? "GET" : "POST";
                message += "\nArguments: ";
                message += rDserver.args();
                message += "\n";
                  message += " " + rDserver.argName(i) + ": " + rDserver.arg(i) + "\n";
                rDserver.send(404, "text/plain", message);
              void mainmenu_image() {
                ezMenu images;
                images.imgBackground(TFT_BLACK);
                images.imgFromTop(40);
                images.imgCaptionColor(TFT_WHITE);
                images.addItem(sysinfo_jpg, "System Information", sysInfo);
                images.addItem(wifi_jpg, "Built-in wifi & other settings", ez.settings.menu);
                images.addItem(wifi_jpg, "WiFi Settings", ez.wifi.menu);
                images.addItem(about_jpg, "About remDisplay", about);
                images.addItem(sleep_jpg, "Power Off", powerOff);
                images.addItem(return_jpg, "Back");
                images.run();
              void powerOff() {
                m5.powerOFF();
              void about() {
              String exit_buttonrD = "Exit";
              void remDisplay() {
                remDisplayPage1();
                while (true) {
                  String btn = ez.buttons.poll();
                  if (btn == "up") remDisplayPage1();
                  if (btn == "down") remDisplayPage2();
                  if (btn == "Exit") break;
              void remDisplayPage1() {
                const byte tab = 120;
                ez.screen.clear();
                ez.header.show("PVControl  (1/2)");
                ez.buttons.show("#" + exit_buttonrD + "#down");
                ez.canvas.font(&FreeSans9pt7b);
                ez.canvas.lmargin(10);
                ez.canvas.println("");
                ez.canvas.print("Produzione:");
                ez.canvas.x(tab);ez.canvas.print(GenP); ez.canvas.println(" W");
                ez.canvas.x(tab); ez.canvas.print(GenE / 1000); ez.canvas.println(" kWh");
                ez.canvas.print("Consumo:");
                ez.canvas.x(tab); ez.canvas.print(UseP); ez.canvas.println(" W");
                ez.canvas.x(tab); ez.canvas.print(UseE / 1000); ez.canvas.println(" kWh");
                ez.canvas.print("Immissione:");
                ez.canvas.x(tab);
                if(NetP > 0)
                  ez.canvas.print(NetP);
                else
                  ez.canvas.print("0");
                ez.canvas.x(tab); ez.canvas.println(" kWh");
                ez.canvas.print("Prelievo:");
                ez.canvas.x(tab);
                if(NetP < 0)
                  ez.canvas.print(abs(NetP));
                else
              void remDisplayPage2() {
                const byte tab = 140;
                ez.screen.clear();
                ez.header.show("PVControl  (2/2)");
                ez.buttons.show("up#" + exit_buttonrD + "#");
                ez.canvas.print("Free RAM:");  ez.canvas.x(tab);  ez.canvas.println(String((long)ESP.getFreeHeap()) + " bytes");
                ez.canvas.print("Min. free seen:");  ez.canvas.x(tab); ez.canvas.println(String((long)esp_get_minimum_free_heap_size()) + " bytes");
              • RopR Offline
                Rop @CrazyHorse80
                @crazyhorse80 I don't see anything that's obviously wrong with it. In serveClients() I would set the return value at 50 instead of 500.Usually there will be nothing to do so it will return quickly. But if there is something to do, half a second is a bit of a long time which adds to other possible timeouts elsewhere and maybe screws things up. That and turning off the errors would be my only two pieces of advice, really. If that doesn't help I don't know...
                C 2 Replies Last reply Reply Quote 0
                  CrazyHorse80 @Rop
                  @rop I've just tried what you said but with no luck at all (it seems to be worst than before)... It must be something related to M5Stack, 'cause if I set another Arduino with the IP of M5Stack it gets a request every minute and it works as intended to. I'l try to setup a program without M5ez and see if it works that way, maybe there's something wrong with interactions between it and the webserver part...
                  Thank you for all your help!
                    CrazyHorse80 @Rop
                    @rop I found where the error was! I was streaming my GET request string to the client with multiple prints and while it is OK for connecting to a web site I send data to and to my MySQL database, it was not OK for the M5Stack.
                    I set up a buffer string, printed all my data in it and then use it to send data to my client object and now it work flawless! I got my stream of data sent every minute!
                    • RopR Offline
                      Rop @CrazyHorse80
                      @crazyhorse80 :)
                        CrazyHorse80
                        Could you please help me with this backtrace I got few moments ago?
                        PC: 0x400853e3: esp_log_write at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/log/log.c line 214
                        EXCVADDR: 0x00000000
                        0x400f54d2: __assert_func at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/bootloader_support/src/bootloader_init.c line 537
                        0x4008de99: vTaskEnterCritical at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/freertos/portmux_impl.inc.h line 106
                        0x4008fd4b: multi_heap_internal_lock at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/heap/multi_heap.c line 372
                        0x400903d3: multi_heap_malloc at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/heap/multi_heap_poisoning.c line 190
                        0x400856b5: heap_caps_malloc at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/heap/heap_caps.c line 110
                        0x400857b9: heap_caps_realloc at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/heap/heap_caps.c line 275
                        0x4008586e: heap_caps_realloc_default at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/heap/heap_caps.c line 162
                        0x40087799: _realloc_r at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/newlib/syscalls.c line 47
                        0x400ead7a: String::changeBuffer(unsigned int) at C:\Arduino-1.8.7\portable\sketchbook\hardware\espressif\esp32\cores\esp32\WString.cpp line 170
                        0x400eadc8: String::reserve(unsigned int) at C:\Arduino-1.8.7\portable\sketchbook\hardware\espressif\esp32\cores\esp32\WString.cpp line 158
                        0x400eade9: String::copy(char const*, unsigned int) at C:\Arduino-1.8.7\portable\sketchbook\hardware\espressif\esp32\cores\esp32\WString.cpp line 195
                        0x400eae23: String::String(char const*) at C:\Arduino-1.8.7\portable\sketchbook\hardware\espressif\esp32\cores\esp32\WString.cpp line 39
                        0x400d8dfa: Timezone::dateTime(long, ezLocalOrUTC_t, String) at C:\Arduino-1.8.7\portable\sketchbook\libraries\ezTime\src\ezTime.cpp line 1164
                        0x400d9622: Timezone::dateTime(long, String) at C:\Arduino-1.8.7\portable\sketchbook\libraries\ezTime\src\ezTime.cpp line 1154
                        0x400d9801: Timezone::dateTime(String) at C:\Arduino-1.8.7\portable\sketchbook\libraries\ezTime\src\ezTime.cpp line 1150
                        0x400e1eb3: ezClock::draw(unsigned short, unsigned short) at C:\Arduino-1.8.7\portable\sketchbook\libraries\M5ez\src\M5ez.cpp line 973
                        0x400de59d: ezHeader::show(String) at C:\Arduino-1.8.7\portable\sketchbook\libraries\M5ez\src\M5ez.cpp line 184
                        0x400d2307: remDisplayPage1() at Z:\_PVControl\M5remDisplay/M5remDisplay.ino line 164
                        0x400d26ba: remDisplay() at Z:\_PVControl\M5remDisplay/M5remDisplay.ino line 152
                        0x400d2c13: handleRoot() at Z:\_PVControl\M5remDisplay/M5remDisplay.ino line 103
                        0x4017b6c1: std::_Function_handler ::_M_invoke(std::_Any_data const&) at c:\arduino-1.8.7\portable\sketchbook\hardware\espressif\esp32\tools\xtensa-esp32-elf\xtensa-esp32-elf\include\c++\5.2.0/functional line 1871
                        0x400d5ee2: std::function ::operator()() const at c:\arduino-1.8.7\portable\sketchbook\hardware\espressif\esp32\tools\xtensa-esp32-elf\xtensa-esp32-elf\include\c++\5.2.0/functional line 2271
                        0x400e9bdd: FunctionRequestHandler::handle(WebServer&, HTTPMethod, String) at C:\Arduino-1.8.7\portable\sketchbook\hardware\espressif\esp32\libraries\WebServer\src\detail/RequestHandlersImpl.h line 42
                        0x400e9c2a: WebServer::_handleRequest() at C:\Arduino-1.8.7\portable\sketchbook\hardware\espressif\esp32\libraries\WebServer\src\WebServer.cpp line 617
                        0x400e9d86: WebServer::handleClient() at C:\Arduino-1.8.7\portable\sketchbook\hardware\espressif\esp32\libraries\WebServer\src\WebServer.cpp line 320
                        0x400d3a44: serveClients() at Z:\_PVControl\M5remDisplay/M5remDisplay.ino line 64
                        0x400dbb68: M5ez::yield() at C:\Arduino-1.8.7\portable\sketchbook\libraries\M5ez\src\M5ez.cpp line 1736
                        0x400dbbb4: ezButtons::poll() at C:\Arduino-1.8.7\portable\sketchbook\libraries\M5ez\src\M5ez.cpp line 612
                        0x400d26c2: remDisplay() at Z:\_PVControl\M5remDisplay/M5remDisplay.ino line 154
                        • RopR Offline
                          Rop @CrazyHorse80
                          @crazyhorse80 Looks like it somehow crashed while M5ez was printing the on-screen clock, but no clue why. Try turning off the on-screen clock... Shouldn't do this no matter what though.
                            CrazyHorse80
                            I need the clock... :( I have that same error every 5 / 7 minutes, it restarts and works for a few minutes again and so on...
                            Maybe I can do some test without the clock to see if it is the cause of the problem...
                            • RopR Offline
                              Rop @CrazyHorse80
                              @crazyhorse80 Maybe show the whole code you're running now?
                                CrazyHorse80 @Rop
                                @rop Here's what my full code looks like at the moment:
                                #include <ezTime.h>
                                #include <M5ez.h>
                                #include <WiFi.h>
                                #include "images.h"
                                  ezt::setDebug(NONE);
                                  ez.begin();
                                  rDserver.begin();
                                  mainmenu.run();
                                  return 50;
                                void handleRoot() {
                                  for (uint8_t i = 0; i < rDserver.headers(); i++) { //debug only
                                    Serial.print(" ");
                                    Serial.print(": ");
                                  for (uint8_t i = 0; i < rDserver.args(); i++) { //debug only
                                    Serial.print(" ");
                                    Serial.print(": ");
                                        rDserver.send(400, "text/plain", " Bad Request");
                                        return;
                                      else {
                                        remDisplay();
                                  else {
                                    return;
                                  message += "URI: ";
                                  message += "\n";
                                  ezMenu images;
                                  images.run();
                                void powerOff() {
                                  m5.powerOFF();
                                void about() {
                                  ez.msgBox("About remDisplay", "");
                                void remDisplay() {
                                  remDisplayPage1();
                                  while (true) {
                                  ez.screen.clear();
                                  ez.canvas.x(tab);
                                  if(NetP > 0)
                                  else
                                  ez.canvas.x(tab);
                                  if(NetP < 0)
                                  else
                                  ez.screen.clear();
                                It's only a part of what I want to achieve and here I'll try to explain what my project should do when it'll be complete:
                                every minute my M5Stack will receive from another Arduino board an HTTP GET request with data and it stores them in global variables and eventually does some operation with them;
                                it should have a multi-page view to show data received and stored in variables (one displays data in numeric form, another will display them in graphs, another one will only change screen background color and make some noise based on data received, and maybe some more);
                                it also should have access to the menus to change wi-fi and screen preferences and some more options related to my program (sound volume, default page to display on startup and so on).
                                I'd also like to have some more widgets:
                                one will have to show me if data received is older than one minute (it means I've lost connection with the Arduino board);
                                another one will have to show the current energy billing band based on what time and day of week it is.
                                The problem with M5ez, and ESP32 in general, is that I've no clue of where to put my code: do I have to do all in loop() function? Or should I register various functions with ez.addEvent()? Or should I do it some other way? I'm a bit confused... Can you show me a proof of concept application using M5ez (even if not related to my needs, so I could understand how it works)?
                                • RopR Offline
                                  Rop @CrazyHorse80
                                  @crazyhorse80 在 I need help with a webserver project... 中说:
                                  • every minute my M5Stack will receive from another Arduino board an HTTP GET request with data and it stores them in global variables and eventually does some operation with them;
                                  • it should have a multi-page view to show data received and stored in variables (one displays data in numeric form, another will display them in graphs, another one will only change screen background color and make some noise based on data received, and maybe some more);
                                  • it also should have access to the menus to change wi-fi and screen preferences and some more options related to my program (sound volume, default page to display on startup and so on).
                                  • one will have to show me if data received is older than one minute (it means I've lost connection with the Arduino board);
                                  Zooming out and looking at your propject:
                                  • Have you considered using mqtt ? I'm no expert, but it seems built for jobs that involve getting values from A to B, figuring out if the sending side is still there, etc etc. All sorts of Arduino libraries for sending and receiving end.
                                  • How to switch between functionality that runs concurrently is always an issue, and there are often more ways to accomplish the same thing. So don't worry too much if it seems hard now. It gets easier to wrap one's head around the program flow with experience, and it sucks in the beginning.
                                  Specifically for this project:
                                  • To make widgets, after reading the user manual it's probably best to study the clock-related code in M5ez.cpp to see how it does its widget things.
                                  • All web handling is done by the webserver code which you have placed in M5ez's main loop with ez.addEvent. The difference between placing code there and placing it in your sketch's loop() function is that loop() is not called when M5ez is waiting for input (like in menus, msgBox, etc etc).
                                  • There is a way to add your own items to the M5ez settings menu. It's in the manual, but again: also look at how it's done inside M5ez.cpp, for example with the clock code.
                                  Good luck!
                                    CrazyHorse80
                                    Thanks for your help, I'll try to follow your directions in the following days.
