    ntptime.getTimestamp returns incorrect timestamp.
    Micropython
    5.8k
    • C
      chhsiao
      version: UIFlow: v1.9.5
      code:
      text = M5Label('text', x=38, y=137, color=0x000, font=FONT_MONT_30, parent=None)
      text2 = M5Label('text', x=38, y=117, color=0x000, font=FONT_MONT_30, parent=None)
      ntp = ntptime.client()
      ts = ntp.getTimestamp()
      year = ntp.year()
      month = ntp.month()
      day = ntp.day()
      text.set_text('%s' % (ts))
      text2.set_text('%s-%s-%s' % (year, month, day))
      expected:
      corrected timestamp as now (2022-09-19 ish).
      saw: some strange timestamp in around 1992. (716937583)
      I'm wondering whether this is within expectation?
        ajb2k3 @chhsiao
        @chhsiao have you set the correct timeszone or tried a different time zone?
        1992 would imply that it doesn’t have a valid time click connection
        • C
          chhsiao
          hi @ajb2k3 ~
          Thank you so much for the reply.
          the year-month-day (text2) shows expected date-time though.
          I would assume that we do have successful ntp connection because of text2.
          In my real code, the time-server is set as our internal time-server, and the timezone is set as 0 (for UTC).
          • C
            chhsiao
            hi @ajb2k3 ~
            As you can see from the screenshot:
            • O
              ondrej1024
              Looks like this ntptime timestamp is relative to 01/01/2000, and not to 01/01/1970 like the Epoch Unix timestamp.
