    Edukit ATECC608B & AWS IOT & UiFlow
    35 Posts 4 Posters 94.2k Views 1 Watching
      ajb2k3 @felmue
      @felmue Sorry, you need to import unit
      Then import units then from units import _ID
      also the code is
      import units
      import unit
      ID_0 = unit.get(unit.ID, (21,22))
      however you can also use:
      import units
      import unit
      ATECC = unit.get(unit.ID, (21,22))
      I don't know why both unit and units (with an S) must be called but they both do.
        Hello @ajb2k3
        thank you again. I tried both your code sequences - still no luck. M5Core2 still reboots after the last command.
        Which UIFlow firmware version is running on your M5Core2?
          ajb2k3 @felmue
          @felmue ok, its been working all day and now crashing
          1.10.2
          OK if you make 1 single mistake, you to to disconnect and power down the Core2 to empty the memory
          this works.
            Hello @ajb2k3
            at this point I think whether the commands succeed or result in a crash depends on the amount of free memory.
            With a freshly rebooted M5Core2 the following commands (sometimes) can be executed w/o crash.
            >>> import unit
            >>> print(ID_0.wakeup())
            True
            >>> print(ID_0.readConfigZone())
              File "units/_ID.py", line 186, in readConfigZone
              File "units/_ID.py", line 363, in read
              File "units/_ID.py", line 377, in read_output
              File "units/_ID.py", line 161, in idle_mode
              File "i2c_bus.py", line 100, in write_list
            OSError: I2C bus error (110)
            True
            >>> print(ID_0.revisionNumber)
            bytearray(b'\x00\x00`\x03')
            Note: The commands need to be executed manually one by one.
            Note: I don't need the import units nor the from units import _ID commands.
              ajb2k3 @felmue
              @felmue said in Edukit ATECC608B & AWS IOT & UiFlow:
              Hello @ajb2k3
              >>> import unit
              True
              True
              Agreed, once the error occurs then memory gets filled requiring hard reset.
              You didn’t need unit or the from? I will try again later.
              I have spent all weekend writing up the atecc for my av2 book including logging the MP modules. I’ll try without those two line tonight.
                The issue of found was that the basic unit functions are in the unit module with unit.ID being empty but the ATecc function are all in units._ID
                  @felmue try adding the following before defining ID_0
                  From esp import gc
                  gc.collect.
                  This should help clean up some memory.
                  Nope that was wrong. the min code I can get running is
                  import unit
                  import units
                  import gc
                  gc.collect()
                  Oh cool, I got import units._ID to work.
                    @gabrielgc75 @felmue I now present to you the configuration loaded from the ATECC608b in my Core2 AWS
                      Hello @ajb2k3
                      thank you. I've tried to add the gc.collect() command. The result is still not 100% persistent. From time to time I still get a crash.
                        ajb2k3 @felmue
                        @felmue thanks for letting me know. It’s been stable for the testing but I’m yet to move beyond. I tried looking at provisioning for vets and codes but my brain is not taking it in hence the low level MP stuff.
                        I’m sure there will s an issue with MP but I don’t deal directly and not getting feedback from @m5stack or @IAMLIUBO
