    Edukit ATECC608B & AWS IOT & UiFlow
    35 Posts 4 Posters 86.8k Views 1 Watching
      Look me up on Amazon (Adam Bryant), I have a crappy getting started book about AWS and UIFlow
      • G Offline
        gabrielgc75 @ajb2k3
        @ajb2k3 Thank you, I found your book at amazon store, but in the description it doesn't say anything regarding how to use the ATECC608B with UiFlow. I have done examples subscribing my edukit to aws iot core, but I have downloaded the certificates directly from AWS, the question is how to use ATECC608B with uiflow. Do you have a book that I could buy with this topic?
        Regards
          Ah no, I'm actually working on adding that to V2 of the book at the moment following your request.
          • G Offline
            gabrielgc75 @ajb2k3
            @ajb2k3 Great! Thank you!, please let me know when it is done.
            Regards
              Just a little update but no matter what I try, as soon as I try to access the I2C bus with the ATECC608, I get a kernel panic and restart.
              @IAMLIUBO @m5stack
                Hello guys
                I did some tests with the AWS bottom:
                • When I stack the AWS bottom to an M5Core2 (using @gabrielgc75 trick with the ID unit and custom pins 21/22) I get a crash - something about I2C master not being initialized.
                • However when I stack the AWS bottom to an M5Stack Basic (again using an ID unit but this time with default Port A) it works and I can access the ATECC608.
                • greenleafG Offline
                  greenleaf @ajb2k3
                  @ajb2k3 It's super buggy. I tried getting this ATECC608 chip working with Arduino code and had very inconsistent results, kernel panics and crashes. The only way I've seen it run consistently is by running the RTOS code in the AWS edukit tutorials.
                    ajb2k3 @felmue
                    @felmue @greenleaf I've reached out to M5Stack to see if they have a solution.
                      Interesting, It seams that the I2C master bus is not being initialised.
                      E (71690) i2c: /home/m5/M5-Workspace/esp-idf-for-m5/components/driver/i2c.c:1273 (i2c_master_cmd_begin):i2c driver not installed
                      E (71692) i2c: /home/m5/M5-Workspace/esp-idf-for-m5/components/driver/i2c.c:1273 (i2c_master_cmd_begin):i2c driver not installed
                      Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
                      Core 0 register dump:
                      PC      : 0x400d29ea  PS      : 0x00060230  A0      : 0x800dffe5  A1      : 0x3ffd3450
                      A2      : 0x3f9530c0  A3      : 0x3f76a89d  A4      : 0x3f953070  A5      : 0x00000000
                      A6      : 0x000000fe  A7      : 0x3ffc4c40  A8      : 0x800d29ea  A9      : 0x3ffd3430
                      A10     : 0x00000000  A11     : 0x00000001  A12     : 0x3f953150  A13     : 0x3ffd3440
                      A14     : 0x0000000c  A15     : 0xff000000  SAR     : 0x0000001a  EXCCAUSE: 0x0000001c
                      EXCVADDR: 0x00000010  LBEG    : 0x40093aa4  LEND    : 0x40093ad2  LCOUNT  : 0xffffffff
                      ELF file SHA256: 0000000000000000
                      Backtrace: 0x400d29e7:0x3ffd3450 0x400dffe2:0x3ffd3470 0x400e0bcc:0x3ffd3490 0x4016d781:0x3ffd34b0 0x4016d7b1:0x3ffd34d0 0x40097d55:0x3ffd3500
                      Rebooting...
                      ets Jul 29 2019 12:21:46
                      rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
                      configsip: 0, SPIWP:0xee
                      mode:DIO, clock div:1
                      load:0x3fff0018,len:4
                      load:0x3fff001c,len:5228
                      load:0x40078000,len:13424
                      load:0x40080400,len:3568
                      entry 0x4008063c
                             _  __ _
                       _   _(_)/ _| | _____      __
                      | | | | | |_| |/ _ \ \ /\ / /
                      | |_| | |  _| | (_) \ V  V /
                       \__,_|_|_| |_|\___/ \_/\_/
                        OK getting somewhere, every time you get a guru or kernel panic you need to hard shut down the core two for 5 seconds or the bug remains in memory.
                          And there is the Issue:
                          The code is not getting run in the correct order!
                          There was a man who had a dog and BINGO! was his Name-O!
                          ![0_1659772116790_Screenshot 2022-08-06 at 08.47.52.png](Uploading 100%)
                          1 Set forward.
                            1 Step Forward!
                            from m5stack_ui import *
                            from uiflow import *
                            import i2c_bus
                            import machine
                            i2c = machine.I2C(scl=machine.Pin(22), sda=machine.Pin(21), freq=133000)
                            screen = M5Screen()
                            screen.clean_screen()
                            label0 = M5Label('label0', x=15, y=43, color=0x000, font=FONT_MONT_14, parent=None)
                            print('Scan i2c bus...')
                            addresses = i2c.scan()
                            print(i2c.scan())
                            label0.set_text(str(i2c.scan()))
                            So the code get run out of order and crashes the i2c bus.
                              Hello @ajb2k3
                              are you doing multiple i2c.scan() calls on purpose? When I try that I only get an empty list. However doing only one scan works for me.
                              I went through older M5Core2 UIFlow firmware versions and all of them crash on me when using the ID unit with custom values for I2C (e.g. 21, 22) in order to access the ATECC608 in the AWS bottom. And UIFlow firmware 1.7.5 doesn't support the ID unit.
                              BTW: The ATECC608B has a sleep mode and when it is in that mode it will not show up during an I2C scan.
                                ajb2k3 @felmue
                                @felmue I'm doing multi scans because I'm not sure how do make one and pass the results to both the Label and print functions.
                                Yeh found out about the sleep mode, you have to hard reset the base plate to wake it up before running an i2C scan.
                                I'm running 1.10.2 and found the issue is in the i2C setup function.
                                Is just a left over function of what I was testing earlier.
                                  And more progress!
                                  I have stable access to the Core2 AWS' ATECC608b
                                  >>> help(_ID.ID)
                                  object <class 'ID'> is of type type
                                    receiveResponseData -- <function receiveResponseData at 0x3f95ce00>
                                    read_output -- <function read_output at 0x3f95d1d0>
                                    publicKey64Bytes -- bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
                                    verifySignature -- <function verifySignature at 0x3f95d260>
                                    wakeup -- <function wakeup at 0x3f95cc90>
                                    dataOTPLockStatus -- False
                                    createNewKeyPair -- <function createNewKeyPair at 0x3f95ce60>
                                    signTempKey -- <function signTempKey at 0x3f95d240>
                                    generatePublicKey -- <function generatePublicKey at 0x3f95d1a0>
                                    getRandomInt -- <function getRandomInt at 0x3f95cdc0>
                                    sha256 -- <function sha256 at 0x3f95d270>
                                    updateRandom32Bytes -- <function updateRandom32Bytes at 0x3f95cd10>
                                    random32Bytes -- bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
                                    KeyConfig -- bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
                                    configZone -- bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
                                    input_buffer -- bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
                                    writeConfigZone -- <function writeConfigZone at 0x3f95d280>
                                    lockDataSlot0 -- <function lockDataSlot0 at 0x3f95ccf0>
                                    signature -- bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
                                    readConfigZone -- <function readConfigZone at 0x3f95ccd0>
                                    get_crc -- bytearray(b'\x00\x00')
                                    countGlobal -- 0
                                    check_crc -- <function check_crc at 0x3f95ce20>
                                    read -- <function read at 0x3f95d1c0>
                                    write -- <function write at 0x3f95d1e0>
                                    __init__ -- <function __init__ at 0x3f95cd90>
                                    slot0LockStatus -- False
                                    createSignature -- <function createSignature at 0x3f95d200>
                                    revisionNumber -- bytearray(b'\x00\x00\x00\x00\x00')
                                    get_info -- <function get_info at 0x3f95ccb0>
                                    getRandomLong -- <function getRandomLong at 0x3f95cdd0>
                                    random_min_max -- <function random_min_max at 0x3f95cdf0>
                                    __module__ -- units._ID
                                    configLockStatus -- False
                                    hash256 -- bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
                                    lockDataAndOTP -- <function lockDataAndOTP at 0x3f95cce0>
                                    random_max -- <function random_max at 0x3f95cde0>
                                    idle_mode -- <function idle_mode at 0x3f95cca0>
                                    calculate_crc -- <function calculate_crc at 0x3f95ce30>
                                    cleanInputBuffer -- <function cleanInputBuffer at 0x3f95ce40>
                                    lock_config -- <function lock_config at 0x3f95ccc0>
                                    __qualname__ -- ID
                                    serialNumber -- bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
                                    lock -- <function lock at 0x3f95cd00>
                                    loadTempKey -- <function loadTempKey at 0x3f95d220>
                                    getRandomByte -- <function getRandomByte at 0x3f95cdb0>
                                    sendCommand -- <function sendCommand at 0x3f95d2c0>
                                    check_count -- <function check_count at 0x3f95ce10>
                                    SlotConfig -- bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
                                  >>> help(_ID.ID.wakeup)
                                  object <function wakeup at 0x3f95cc90> is of type function
                                  >>> help(_ID.ID.get_info)
                                  object <function get_info at 0x3f95ccb0> is of type function
                                  >>> help('_ID.ID.get_info')
                                  object _ID.ID.get_info is of type str
                                    encode -- <function>
                                    find -- <function>
                                    rfind -- <function>
                                    index -- <function>
                                    rindex -- <function>
                                    join -- <function>
                                    split -- <function>
                                    splitlines -- <function>
                                    rsplit -- <function>
                                    startswith -- <function>
                                    endswith -- <function>
                                    strip -- <function>
                                    lstrip -- <function>
                                    rstrip -- <function>
                                    format -- <function>
                                    replace -- <function>
                                    count -- <function>
                                    partition -- <function>
                                    rpartition -- <function>
                                    center -- <function>
                                    lower -- <function>
                                    upper -- <function>
                                    isspace -- <function>
                                    isalpha -- <function>
                                    isdigit -- <function>
                                    isupper -- <function>
                                    islower -- <function>
                                  >>> import i2c_bus
                                  NameError: name 'machine' isn't defined
                                  >>> import i2c_bus
                                  >>> Import machine
                                  SyntaxError: invalid syntax
                                  >>> import machine
                                  >>> print(i2c.scan())
                                  [52, 53, 56, 81, 104]
                                  >>> import units
                                  >>> from units import _ID
                                  >>> i2c.wakeup
                                  AttributeError: 'I2C' object has no attribute 'wakeup'
                                  >>> ID_0 = unit.get(unit.ID, (21,22))
                                  >>> ID_0.wakeup
                                  <bound_method>
                                  >>> ID_0.ID.wakeup
                                  AttributeError: 'ID' object has no attribute 'ID'
                                  >>> ID_0.get_info
                                  <bound_method>
                                  >>> print(ID_0.get_info)
                                  <bound_method>
                                  >>> print(ID_0.get_info())
                                  True
                                  >>> print(ID_0.wakeup())
                                  True
                                  >>> print(ID_0.read_output())
                                  TypeError: function takes 5 positional arguments but 1 were given
                                  >>> print(ID_0.readConfigZone())
                                  True
                                  >>> print(ID_0.revisionnumber())
                                  AttributeError: 'ID' object has no attribute 'revisionnumber'
                                  >>> print(ID_0.revisionNumber())
                                  TypeError: 'bytearray' object isn't callable
                                  >>> print(ID_0.revisionNumber)
                                  bytearray(b'\x00\x00`\x02')
                                  >>> print(ID_0.serialNumber)
                                  bytearray(b'\x01#\xce\xa0\xcf\x06\x90\x0b\x01')
                                  Datalog dump from Thonny!
                                    ajb2k3 @ajb2k3
                                    >>> print(ID_0.loadTempKey(64))
                                    True
                                    >>> print(ID_0.generatePublicKey())
                                    True
                                    >>> print(ID_0.publicKey64Bytes)
                                    bytearray(b'\x84\xf8\xda\xf6\xda\x18&r\x1b\xf0\xdbv\x1a\xcc\xf6z\xfd\xe2>\xdcY\xd5l\xf4kk\xb7D\xffI6\x1d\xcfDO\x9f\xc8bv\x80\xa9\xb8\xe75\xc5\x13\xe4\xe91\x9b\xcelg\xeb\x01Q\x18\xd0<\x91\xcb\xd8\xc1\xa1')
                                    Generate and display a key!
                                      And a guide:
                                      https://www.hackster.io/AJB2K3/accessing-the-atecc608b-in-uiflow-part-1-5ac679
                                        Hello @ajb2k3
                                        thank you for putting together the guide. Unfortunately I cannot get it to work. I do not fully understand the following instructions from your guide.
                                        Now I have the basics after poking away at micropython I import machine and units._ID0
                                        import units
                                        Using Thonny and ...
                                        ... trying to import units._ID0 results in an error.
                                        ... where is _ID used?
                                        ... trying to run ID_0 = unit.get(unit.ID, (21,22)) still crashes my M5Core2.
                                          ajb2k3 @felmue
                                          @felmue It will.
                                          You have to run the commands in that exact order or it will crash and restart!
                                          If you run help('modules') in Thonny you will find the module units/_ID this took me house to work out.
                                          _ID0 does not exist, the module is _ID
                                            Hello @ajb2k3
                                            thank you. I appreciate all your help. Unfortunately for some reason I cannot get it to work on my side. Whatever steps I execute before, every time I try to execute ID_0 = unit.get(unit.ID, (21,22)) my M5Core2 crashes.
