    Is machine.deepsleep() possible with a Core 2?
    3 Posts 2 Posters 4.1k Views 2 Watching
    • greenleafG Offline
      greenleaf
      I have a Core 2 for AWS but figured the base hardware is the same so this should apply to the Core 2 as well.
      When I tried to do a machine.deepsleep(10000) the device just goes into a boot loop. It doesn't wait ten seconds. Seems like it might be trying to go to sleep then immediately restarting.
      Anyone have deepsleep working on a Core 2 device?
      It definitely gets the deepsleep signal, this is what I see in the serial output
      rst:0x5 (DEEPSLEEP_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff0018,len:4
      load:0x3fff001c,len:5228
      load:0x40078000,len:13424
      load:0x40080400,len:3568
      entry 0x4008063c
             _  __ _
       _   _(_)/ _| | _____      __
      | | | | | |_| |/ _ \ \ /\ / /
      | |_| | |  _| | (_) \ V  V /
       \__,_|_|_| |_|\___/ \_/\_/
        Hello @greenleaf
        works fine here with:
        from m5stack import *
        from m5stack_ui import *
        from uiflow import *
        import machine
        screen = M5Screen()
        screen.clean_screen()
        When I run this code from UIFlow the screen goes white and after about 10 seconds M5Core2 restarts and connects back to UIFlow. Not sure why in your case it doesn't wait 10 seconds. Do you have the latest UIFlow firmware 1.10.2 installed on your M5Core2?
          greenleaf @felmue
          @felmue I think I found the issue; my deepsleep() call was inside a loop. Moving it outside the loop sorted it out.
