    Azure IoT Speaker play_cloud command broken
    Bug Report
    1.8k
    • greenleafG
      greenleaf
      This Azure handler won't play cloud based wav files. The play_local works fine though. The error message shown when trying to play a WAV URL is below:
      Unhandled exception in thread started by <bound_method>
        File "libs/m5mqtt.py", line 101, in _msg_deal_task
        File "libs/m5mqtt.py", line 88, in update
        File "umqtt/robust.py", line 80, in check_msg
        File "umqtt/simple.py", line 271, in check_msg
        File "umqtt/simple.py", line 259, in wait_msg
        File "libs/m5mqtt.py", line 50, in _on_data
        File "IoTcloud/Azure.py", line 333, in direct_method_cb
        File "<string>", line 33, in azure_direct_Speaker_play_cloud
        File "hardware/speaker.py", line 135, in playCloudWAV
        File "hardware/speaker.py", line 82, in playWAV
      ValueError: Data Format is not valid
