M5Fire and MLX90640 works
Since the MLX 90640 module is also available from M5Stack, the following software also runs with the MLX 90640 thermal camera.
Here is the link to the software: https: //github.com/m5stack/M5Stack/tree/master/examples/Modules
I have just tested it with a M5Stack Fire with 32GB SD card -
@skink 在 M5Fire and MLX90640 works 中说:
I have just tested it with a M5Stack Fire -
I just tested it successfully with M5Stack Basic.
I've tried it with the fire as well and for me it doesn't work :\ Nothing works with m5stack
@lastcaress 在 M5Fire and MLX90640 works 中说:
Tried it also on a m5stack core, and ... nothing!
@LastCaress,
maybe you have not installed all the drivers on your Arduino software, work with Arduino 1.8.7 and I work with the sensor as I said with the M5Stack Fire and the M5Stack Basic (black), have attached a few pictures here, no SD card installed nothing, only the port used to the sensor rübergeführt and already the sensor runs on M5Stack!
Greetings Skink
The red is the battery unit
Greetings Skink -
The code was compiling, it just didn't do anything when I connected the camera. Tried m5 core, fire and nothing. Tried today with m5go and it worked!
I think i have too many m5stack things
@LastCaress
with me it looks almost exactly as in your picture under your profile on the workplace (Unfortunately, I do not have so many sensors).
What I noticed, however, was that I had the IR remote sensor from the M5Go package and it did not work on the M5Go (wise M5Stack) either, because the port (B) seems to be defective because it worked on the M5 Fire. Have then sent the part complete with sensors !!
Because software was the same installed on both, on the M5Stack Fire one saw with the mobile phone that the IR sensor sends when connecting to the M5Go where the sensor was received, the IR sensor did not send !!
Do not check that the M5Stack is not working because of the warranty
Greetings Skink -
thats quite a collection you have there.
