    AWS IoT Edukit Core M5 - Micropython support?
    Core2 for AWS
    6
    12
    19.2k
    • greenleafG
      greenleaf
      The AWS IoT Edukit Core M5 requires you to build your own firmware using the ESP-IDF build framework.
      Will the extra hardware features like the RGB leds, microphone and crypto module be supported with an m5burner micropython image?
      • ZontexZ
        Zontex
        Yes it's supported, you could use the Core2 AWS like a normal version core2
        • R
          rashedtalukder
          @greenleaf, after doing some initial quick testing I found that many of the features are in parity, but things like the RBG LED is not functional because the pins are different from the M5Stack Fire. You might be able to take the existing M5Stack MicroPython library and update the pins to work with it.
          The crypto module isn't supported. However, you can use the Adafruit Crypto library for the secure element.
          M5Stack and AWS are working together to explore an option to deliver a MicroPython package specifically for the Core2 for AWS IoT EduKit.
          Head of the AWS IoT EduKit program and AWS employee. Not an M5Stack employee.
          greenleafG F 2 Replies Last reply Reply Quote 1
          • greenleafG
            greenleaf @rashedtalukder
            @rashedtalukder Super! An officially supported MicroPython package for the Core2 for AWS would be amazing.
            • F
              flex @rashedtalukder
              @rashedtalukder said in AWS IoT Edukit Core M5 - Micropython support?:
              waiting for that MicroPython package specific for the Core2 for AWS... When?
              • greenleafG
                greenleaf
                Hi @rashedtalukder - it's been a while. Is AWS still committed to bringing Micropython to this device?
                ajb2k3A R 2 Replies Last reply Reply Quote 0
                  ajb2k3 @greenleaf
                  @greenleaf I haven't heard anything but there are functions in UIFlow provided for this and I have written and published a guide but am rewriting and updating a guide to AWS using UIFlow.
                  • greenleafG
                    greenleaf @ajb2k3
                    @ajb2k3 Thanks. Yes, it looks like UIflow has evolved quite a bit since last year. I'm happy to see you can execute custom code now, and that there are some dedicated hooks for things like AWS IoT.
                    • R
                      rashedtalukder @greenleaf
                      @greenleaf I recently left Amazon. I don’t know what their plans are.
                      ajb2k3A greenleafG 2 Replies Last reply Reply Quote 0
                        ajb2k3 @rashedtalukder
                        @rashedtalukder just spent the last 7 days hacking the code and making progress.
                        • K
                          kulmam92
                          I was able to send data to AWS IoT Core using the below code. If you want to run this code from VScode + Pymakr, follow this guide: MicroPython: Program ESP32/ESP8266 using VS Code and Pymakr
                          import network
                          from umqtt.simple import MQTTClient
                          import time
                          import sys
                          import os
                          import json
                          # configure your wifi credentials
                          WIFI_SSID = "<YOUR_WIFI_SSID_GOES_HERE>"
                          WIFI_PASS = "<YOUR_WIFI_PASSWORD_GOES_HERE>"
                          # configure your iot credentials
                          MQTT_ENDPOINT = "XXXXXX.iot.XXXXX.amazonaws.com"
                          MQTT_PORT = 8883
                          MQTT_QOS = 0
                          # thing-id
                          MQTT_CLIENT = "mycore2"
                          THING_CLIENT_CERT = "/flash/res/core2-certificate.pem.crt"
                          THING_PRIVATE_KEY = "/flash/res/core2-private.pem.key"
                          # topic
                          MQTT_TOPIC = "mycore2/env"
                          MQTT_SUB_TOPIC = "mycore2/command"
                          info = os.uname()
                          def connect_to_wifi(ssid, password):
                              sta_if = network.WLAN(network.STA_IF)
                              if not sta_if.isconnected():
                                  sta_if.active(True)
                                  sta_if.connect(ssid, password)
                                  while not sta_if.isconnected():
                                      pass
                              ip_address = sta_if.ifconfig()[0]
                              return ip_address
                          def get_key(key_path):
                              with open(key_path, "r") as f:
                                  key = f.read()
                              return key
                          def connect_to_mqtt():
                              print("CONNECTING TO MQTT BROKER...")
                              global client
                              client = MQTTClient(
                                  client_id=MQTT_CLIENT,
                                  server=MQTT_ENDPOINT,
                                  port=MQTT_PORT,
                                  keepalive=0,
                                  ssl=True,
                                  ssl_params={
                                      "cert": get_key(THING_CLIENT_CERT),
                                      "key": get_key(THING_PRIVATE_KEY),
                                      "server_side": False
                              client.set_callback(subscription_call_back)
                              try:
                                  client.connect()
                                  print("MQTT BROKER CONNECTION SUCCESSFUL")
                              except Exception as e:
                                  print("MQTT CONNECTION FAILED: {}".format(e))
                                  sys.exit()
                              client.subscribe(MQTT_SUB_TOPIC)
                              print("SUBSCRIBED TO TOPIC: {}".format(MQTT_SUB_TOPIC))
                              return
                          def subscription_call_back(topic, msg):
                              # confirm state update
                              print("RECEIVING MESSAGE: {} FROM TOPIC: {}".format(
                                  msg.decode("utf-8"), topic.decode("utf-8")))
                              return
                          def publish_message(topic, msg, qos=MQTT_QOS):
                              client.publish(
                                  topic=topic,
                                  msg=msg,
                                  qos=qos)
                              print("PUBLISHING MESSAGE: {} TO TOPIC: {}".format(msg, topic))
                              return
                          # connect to wifi
                          print("CONNECTING TO WIFI NETWORK")
                          ip_address = connect_to_wifi(WIFI_SSID, WIFI_PASS)
                          print("CONNECTED SUCCESSFULLY")
                          print("YOUR IP ADDRESS IS: {}".format(ip_address))
                          # connect to mqtt
                          print("CONNECTING TO MQTT BROKER")
                          connect_to_mqtt()
                          print("SUBSCRIBED TO TOPIC")
                          while True:
                              client.check_msg()
                              tf = power.getTempInAXP192()
                              msg = str(json.dumps({
                                  "client": MQTT_CLIENT,
                                  "device": {
                                      "uptime": time.ticks_ms(),
                                      "hardware": info[0],
                                      "firmware": info[2]
                                  "sensors": {
                                      "TempInAXP192": tf
                                  "status": "online",
                              publish_message(MQTT_TOPIC, msg)
                              time.sleep(5)
                          • greenleafG
                            @rashedtalukder Congrats, hope you are on to somewhere that appreciates your skills!
